ID this pipe
[Closed] ID this pipe
[#840588]
This is in the corner of my kitchen. I assume it's an old water main...can I just pull it out?
Posted : 05/09/2009 8:38 am
then you'll have to do some more plastering again 🙄
You're making a meal of this kitchen arent you al? 😉
Posted : 05/09/2009 8:40 am
go for it but be sure to let us know what happens
Posted : 05/09/2009 8:41 am
Yes I will stoner...and I am making meal of it....but us top city hotshots have limited time for teh DIY ken?
So no one knows?
Posted : 05/09/2009 8:45 am
Try a pilot drill and see what comes out of it?
Posted : 05/09/2009 8:46 am
you could try shutting the valve and seeing if something stops working (gas, water, draught beer)
Posted : 05/09/2009 8:47 am
Go for it al! Kango that baby out of the wall - and take plenty of pics!
I am assuming the valve is shut...it looks like the old water main going up to the tank in the attic.
Ah well I can just mdf over it.
Posted : 05/09/2009 8:51 am
Oh and I should have filmed myself plumbing in the radiator last week - I CBA draining the system. Quite a lot of water everywhere!
Posted : 05/09/2009 8:52 am
Mihgt be gas, or old central heating . depeends on when your house was built . Looks the same as my mums central heating that was fited in the 50's .
Why did you not think to either box it in or remove it before plastering?
Posted : 05/09/2009 9:00 am
Cos I thought I'd box it in after plastering...and I don't think these things through, I'm a bit of a "have a go" type.
Need to cover current water main on adjacent corner so at least there will be a bit of symmetry
Posted : 05/09/2009 9:03 am
The valve is solid, but pipe makes a hollow sound when tapped 😕
Posted : 05/09/2009 9:19 am
Gas pipe then!
Make sure you get some piccies of your house burning down. 😀
Posted : 05/09/2009 9:34 am
Just looked at the picture again.
Is that blue plastic pipe at the bottom? If so probably water pipe and not gas, shame, and safe to remove. 😉
Posted : 05/09/2009 9:36 am
That looks remarkably like an old gas pipe we have in the cellar
Posted : 05/09/2009 9:37 am
cynic-al and TJ, destroying Scottish buildings since 2008.
Posted : 05/09/2009 9:42 am
[i]Is that blue plastic pipe at the bottom? If so probably water pipe and not gas, shame, and safe to remove. [/i]
Or it could have been gas piped in Blue alkathene like was done in an entire high rise as discovered when it was to be signed off.
[b][u]Dont assume anything about the pipe unless you can trace at least one end of it!![/b][/u]
Posted : 05/09/2009 9:49 am
It's blue paint. Have emailed a plumber mate but I am thinking Smudger's advice is good.
Mike your party invite is hereby, hencewith & muchforth REVOKED 😡
Posted : 05/09/2009 11:38 am
