Helmet mounting thi...
[Closed] Helmet mounting this torch - how?
[#3599967]
looking at the enclosed mount - it appears that itmay swivel. I am thinking of something along the line of the joystick mount.
Any ideas of what to do?
Posted : 23/01/2012 8:12 pm
I'm using a joystick mount now for mine, but previously used a blob of blutack and some red post office rubber bands recovered from the front path.
Posted : 23/01/2012 8:41 pm
doe sit fit into a joystick mount with no issues?
Posted : 23/01/2012 8:45 pm
🙂 works great for me
Posted : 23/01/2012 8:47 pm
[url= http://www.photonlight.com/accessories/twofish-lockblocks-flashlight-bike-mount/?Source=GDF_GoogleBaseUK&gdftrk=gdfV21383_a_7c1216_a_7c5206_a_7cTF_d_FLASHLIGHTBLOCK ]These help[/url] various versions are available from multiple sources, i used one on a Giro Xen with a foam block & a ziptie to adjust the angle & help with stability. Or just use zipties..
Posted : 23/01/2012 9:03 pm
Similar to the elastic band, chop up an old innertube...
Posted : 23/01/2012 9:06 pm
cruzheckler - Member
Ah- it's not the same model of torch.
Posted : 23/01/2012 9:08 pm
my question is specifically about modding the mount it coems with to make it like the joystick helmet mount
Posted : 23/01/2012 9:13 pm
scrap the mount and get some reuseable cable ties. you'll then have a world of options
Posted : 23/01/2012 9:17 pm
not an option
Posted : 23/01/2012 9:57 pm
have you got one of those Rob ? any good ? I'm looking for a new head torch
Posted : 26/01/2012 11:24 pm
Cut the lower section off the handlebar mount to leave a low profile C section,(like it looks behind the red light in your pic) line it up with the light body, drop it thru a vent and twist the lower section 90 degrees so it snugs up against the sides of the vent, If you've got a threaded bolt in there, you can then clamp it down with the bolt and it should make a good interference fit similar to the exposure mount.
Obviously, test it'll work before you cut off the excess.
Posted : 27/01/2012 12:23 am
Get yourself a second helmet and gaffa it on!!
Posted : 27/01/2012 6:37 am
ordered but not arrived yet
Posted : 27/01/2012 7:31 am
