Without stripping my bike; – can anyone tell me what the outside diameter of the headset (internal diameter of the head tube) might be.
The Bike is a Cube Ltd, and has a 50mm OD head tube, and has an FSA #10 headset. I’ve tried the FSA website, but the names have changed, so #10 didn’t appear anywhere meaningful.
I reckon the dimension in question will be either c.41mm or 44mm, but am asking for confirmation, as if it is 44mm I’d be able to run an external lower bearing (and hence a tapered steerer fork).
The Cane Creek site apparently lists all sorts of combinations of bearings, but you need to input the ID of your head tube – which kinda negates the question..
Help appreciated, cheers.
