[Closed] Have you ever drilled and tapped cranks, to make shorter?
My boys bike build is going well, but the crank arms are too long- can they be drilled and tapped?
I have mates with the right gear I think.
Don't they get wider where the pedal hole is ?
If you drill them further down, you'll be making a hole in the narrower part which will weaken them.
How big and strong is the boy ?
There must be a safety margin, if you're shortening the cranks because he's only little, they probably won't break.
I doubt it as this will affect the strength of the crank too much, but it might depend on the crank
It's a very thick set off a downhill bike. I recon I could drill lots of extra holes to lighten, and I wouldn't snap them.
I seem to remember there was a company offering a crank shortening service, so it can be done but they could only do solid cranks.
EDIT- here you go, http://www.highpath.net/highpath/cycles/shorten.html
Nice, thanks.
fwiw trek kids bikes (well, my kids 20" ones in any case) come with cranks with 2 holes in each to move the pedals further down the crank as child grows. The arms are alloy too.
Also/but, riding with even a not-very-bent crank is most peculiar: (anyone want an old and lightly bent fsa megaexo crank/bb?) -you'll need to get the location and angle of the drilling absolutley bob-on or they will ride 'bent'.
Ben, any tips will be welcome.
