Viewing 14 posts - 1 through 14 (of 14 total)
  • GXP crank + Shimano BB30 compatability?
  • All-On-Black
    I’ve been running a Truvativ X0 crank on my hardtail with an external BB from Hope, plus the adapter to take the GXP crank.. However I’m about to purchase a new frame that has an already installed Shimano BB30..
    So what do I need to get it to fit? I’m guessing putting the adapter rings in the new frame won’t work!?
    Or do I also have to buy a GXP BB30?
    Rorschach
    Shimano don’t do bb30.
    There’s pressfit bb90.
    Theres bb30.
    There’s pressfit bb30.
    What frame?
    All-On-Black
    I realised that after I posted, it’s the Yeti AR-Sc frame..
    Rorschach
    All-On-Black
    Thanks a bunch! But, won’t the bearings on that be terrible? Do I basically just need a GXP BB92? Although it’s a 73mm shell width..
    All-On-Black
    Wait, so am I right in thinking that you can’t run any GXP cranks on the frame at all..?
    Rorschach
    What year?
    I was under the impression it was bb92.
    Puzzled I am.
    Does it look like this? (bb is in)
    All-On-Black
    I’m really confused about this too.. it’s 2009.
    So I thought, ah, it must be the Truvativ GXP BB with ceramic bearings.. but that says it’s for 92mm shells.. and in brackets says that standard GXP is 68 – 73mm shells.. so which is which?!
    Confused.com
    Rorschach
    It is BB92 (which is misnomer as the shels are 89.5mm or 91mm but we’ll skip over that).
    If it has threads its 68/73.If not its 92.
    All-On-Black
    that’s it in the photo, yeh.
    However, the description says it’s press fit, which it is, judging by the picture, but also says it’s a 73mm shell..
    STATO
    AOB, your not being very clear. what says its a 73mm shell, the frame or the BB?
    All-On-Black
    Sorry.. i msorry i mean the description says its a 73mm shell in the specs of the frame.. but says its press fit in the description of the frame
    STATO
    Thats just the Yeti I.T web guy being dumb. The press-fit linked above is what you need as others have said.
    All-On-Black
    No wonder ive been getting so confused! so its bb92 then.. ok thanks for your help guys much appreciated!!
The topic ‘GXP crank + Shimano BB30 compatability?’ is closed to new replies.
