GT85... where to st...
[Closed] GT85... where to stick it.
[#3786074]
As an engineer i understand how important lubrication is on metal to metal parts. Thing is, our bikes have a tonne of seals and grease that you dont want to contaminate. So where do you actually use the stuff? Do you spray it into all the nooks n krannies?
Posted : 18/03/2012 11:10 pm
I spray it round the house as an air freshener.
Posted : 18/03/2012 11:11 pm
Spray it on the disc rotors. Helps clean 'em.
Posted : 18/03/2012 11:12 pm
 Taff
Spray everywhere! Soak the chain to avoid rust spots, down tube to avoid mud at sticking. Don't necessarily spray pivots full pelt but enough for water dispersion
I don't spray it anywhere I want to stay water tight!!
behind each ear before I go out - drives the muddy boys wild
Posted : 18/03/2012 11:13 pm
in other words, use it as a chain lube or dont bother as its ***t. my thoughts exactly. Although, i find if you fancy dodgy skin on your hands it comes in pretty handy.
It handy for cleaning mud out of the corner if your eye too, epecially with that straw.
Posted : 18/03/2012 11:23 pm
I use it on gear cables and the front and rear mechs. Occaisionaly on seat clamp and pedal spindles. I avoid it near bearings.
Posted : 18/03/2012 11:25 pm
Nowt better for making anodised frames nice and sparkly though
Posted : 18/03/2012 11:26 pm
 P20
Its good for putting on grips
I don't really bother with it any more - generally silicon spray does just as good a job, and doesn't cock up seals, bearings, etc.
Posted : 18/03/2012 11:27 pm
Front and rear mechs - that's about it.
Posted : 18/03/2012 11:29 pm
Same as steezysix.
Ditched it along time ago for silicon spray...just sniff it now... 😉
Posted : 18/03/2012 11:46 pm
Good on mechs. Not at all bad as a penetrating lubricant on sticky bolts. OK as a mud-shedder or paintwork cleaner. Pretty damn poor as a chainlube. Not much use anywhere else.
Posted : 18/03/2012 11:50 pm
I'd never found a use for it really. Suppose it's ok for removing stickers and cleaning some bits.
Posted : 18/03/2012 11:54 pm
When a component is stuck, I spray a bit on it before hitting it with a hammer. I'm not sure it does anything, but it smells nice.
Posted : 19/03/2012 12:23 am
I also soak my mechs in the stuff as part of my post ride ritual, then work it in before wiping most of it back off again...
Chain gets Finish Line Winter lube all year round 'cos i have a couple of huge bottles I bought in a sale and it seems to work just fine 🙂
Posted : 19/03/2012 12:29 am
It's a good firelighter.
Posted : 19/03/2012 12:44 am
I use it for front, rear mechs, cassette and buff up,the black components on my bike after a wash like seat post, bars etc. I also uses it in my car interior for a the plastic bits.
Posted : 19/03/2012 7:52 am
I use it on rear mech and soak chain after a wet ride or a bike wash with it.
Posted : 19/03/2012 7:59 am
I spray it all over my 450 enduro bike when I've washed it to stop the water corroding the engine casing. I also spray it on a rag and wipe my frame over when I've given it a really good clean, but that's about once every 6 months to be honest.
Posted : 19/03/2012 9:09 am
post wash water disperser, but avoid suspension, seals, brake levers etc. Also good for mechs. stops stem bolts etc rusting. Spray liberally around garage regularly for the smell 😆
Posted : 19/03/2012 9:18 am
Who said its good for putting on grips?
its only good for the bin.
Posted : 19/03/2012 9:36 am
Post ride I use it on crank and front mech, rear mech and cassette. Also use it to drive water out of the chain post wash, then wipe down chain and apply lube ready for next ride.
Wouldnt use it on anything else really apart from paint work. Be careful though as its very easy to contaminate pads which can get expensive.
My bikes always look like new after every ride.
Posted : 19/03/2012 9:43 am
I wouldn't use it to put on grips, it doesn't flash off clean- it'll leave oil and ptfe under the grip. Isopropyl alcohol makes much more sense.
Posted : 19/03/2012 9:02 pm
bwaarp - Member
This is, virtually word for word, something a mate said to me in all seriousness recently.
Posted : 19/03/2012 9:28 pm
Good at dispersing water after washing and for cleaning stuff.
Posted : 19/03/2012 9:29 pm
are you sure he isn't after your missus?
I use it on front and rear deraileurs and for cleaning my rims around the spokes after washing (as it drives out water and stops corrosion of the nipples!). Works well for freeing up sticky derailleur pivots.
Also use it on SPD mechanisms. Use the spray grease version (green can) inside shifters - works very well.
Posted : 19/03/2012 9:37 pm
It works very well at getting grease & oil out of cream carpets.
Posted : 19/03/2012 9:42 pm
Not required or useful anywhere for properly maintaining a bicycle.
I was waiting in the carpark at Brechfa a while back and watched some guy give his whole bike a gentle misting of GT85, brakes included, then put on his helmet and ride off up the hill. All his mates on much more expensive bikes didn't seem to bat an eyelid at it. I'm guessing that maybe there's a joke on him that he didn't get...
And what do I do with it? Don't own any.. Can't stand the smell.
Posted : 19/03/2012 10:11 pm
+1 for firelighter. I used it to help lauch the new year lanterns in the high winds. What could possibly go wrong? The burning bushes were quite biblical!
Its great for post-wash frame shining. The smell is so comforting. I keep it away from greasy bits. No good as chain lube of course. I
Posted : 19/03/2012 10:19 pm
Dont get it anywhere your brake pads. They will be defunked.lol.
Posted : 19/03/2012 10:48 pm
I mainly use it as a polish and spray my mechs with it. Why is it so bad to use near seals and bearings etc?
Posted : 19/03/2012 11:13 pm
 devs
It's a penetrant that dissolves grease. It penetrates past the seals and dissolves the grease on your bearings. When it's gone it's gone. Rust and wear and bad things happen!
Posted : 20/03/2012 12:16 am
devs - Member
Where does it go?
Posted : 20/03/2012 12:26 am
MTB Chainlube is surely the biggest case of emperor's new clothes since well, the proverbial. You need to lube a chainsaw, you need to lube a moto chain, you need to lube a timing chain. You could literally take a piss on your MTB chain and it would be sufficiently lubed.
Posted : 20/03/2012 12:27 am
Mmmmm my randomjeremy. That sounds like bollocks to me. I tried not luring my chain for a year, and broke about 4 chains. Haven't broken one in about 5 years since I started lubing them.
Posted : 20/03/2012 12:39 am
GT85 the only lubricant you need for external lubrication.
It does what it says on the tin.
Posted : 20/03/2012 12:52 am
Like three fish says.
I don't use it on the bike at all, but I have a decanted pot that I use to 'dip' my chains in after I've purged the degreaser with a garden hose.
It gets the water out and I can lube straight over the top. With the chain hanging off of a nail it does a fine job of carrying the water and remaining muck into a pot.
Posted : 20/03/2012 8:35 am
Prefer Tf2 myself. 😉
Posted : 20/03/2012 8:44 am
Yes well you should lube your chain with something, that's obvious surely. But wet, dry, wax , special concoctions that cost ten quid for a tiny bottle? A bit of GT85 or WD40 or what have you is more than enough 🙂
Posted : 20/03/2012 1:35 pm
On the Sheldon Brown website he mentions that there are folk who's opinions he values who "preserve" chains rather than "lubricate" them. Some people think thick lubes attract dirt which then acts like a cutting paste accelerating wear. A spray with GT85 will stop rusting. I have tried both methods and find the chains last about the same either way. Shifting over long rides is not greatly effected. Preserving chains has the benefit of easy cleaning and not have black gloop over jockies, scrockets and chainrings.
Posted : 20/03/2012 2:09 pm
Oooo.
Black gunk on your scrockets. Nasty. I've heard about that. I think you can get a cream for it these days.
Posted : 21/03/2012 9:11 pm
I find it attracts dirt which sticks to the frame or mech etc. Are there any less sticky lubes for the mechs?
Like what Micky said. I guess rust is as big a factor as having dirt in the chain!
For chains I like Rock N Roll Extreme, which works in very wet or dry dusty conditions - and keep my chain clean with no effort. I simply back peddle a few times after slapping it on then wipe excess. Finish line wet got my chain looking black after every ride, even though I wiped it down to remove excess! And wipe it down too much and it starts sweaking. So Rock N Roll Extreme for the chain for me! And not sure what works best for mechs.... GT85 seems too sticky for mud to me. Need something better.
I lost a bike due to GT85, I put a load down the BB area through the seatpost after I left the seat off while bike was on the car and it rained into it. This was a younger and less wise version of me and I thought it would get rid of the water. But it got rid of the greece instead 🙁 BB rusted in, impossible to get out!
Posted : 02/04/2012 2:59 pm
