GCSE Questionnaire
[Closed] GCSE Questionnaire
[#285034]
What is the right amount of travel on a aggressive hard tail?
Best frame material for a hard tail?
Preferred top tube length?
Preferred frame size?
Preferred wheel size front and rear?
Slack ,steep, or somewhere in the middle. -(Head tube angle)
How much would you pay for a highly specked aggressive hard tail?
Singlespeed or geared?
Hard tail or rigid ?
Big tyres 2.35+ or small tyres anything up to 2.35?
Thick tubes or small tubes for the frame?
Low BB or high BB?
ta Al
Posted : 07/02/2009 10:54 pm
Define aggressive!? I'd say:
120mm
Carbon
The right length (no idea what any of my bikes are)
17"-18"
26"
Middle
As much as it was worth- my FS is over £4500 in the shops, so not really bothered!
Geared
Hardtail
Less than 2.35"
Depends on material
Middle
Bear in mind I'm an XC racer, and would never actually buy an 'aggressive hardtail' I'd sooner have a 5" travel FS, but I'm bored, and my answers are still valid I guess!
Posted : 07/02/2009 10:58 pm
If this is for a piece of c.work you may want to set up an online survey. Much easier for you to collate the info and user friendly for people to use.
Posted : 07/02/2009 11:00 pm
130mm
steel
22.75
18"
26"
69/70deg
250 for the frame, upto a grand maybe on a build?
geared
Hard tail
2.1-2.35 dependig on my mood
steel, so generaly on the smaller side
Low BB
You missed out chainstay length, which should be as short as physicaly possible. any my top tube is on the short side as i run 90mm stems.
Posted : 07/02/2009 11:45 pm
Is this a trick question.....
Posted : 07/02/2009 11:47 pm
Cheers for that spoon.
unsponsered I just really need everyday bikers normal people plus this is easy as school haven't blocked this site yet .
Stu it's not a trick Question Promise 🙂
"aggressive" By that i mean a bike your going to chuck down single track (not literately) a bit towards freeride I suppose jumps drop big rock gardens etc lots of roots very technical stuff. if you get me
(m)Alex
Posted : 08/02/2009 12:07 am
 rj
What is the right amount of travel on a aggressive hard tail? 130mm
Best frame material for a hard tail? Steel/Unobtanium
Preferred top tube length? 22.5"
Preferred frame size? 16"
Preferred wheel size front and rear? 26/26
Slack ,steep, or somewhere in the middle. -(Head tube angle) Probably
How much would you pay for a highly specked aggressive hard tail? £1500 absolute max.
Singlespeed or geared? Don't be silly, I'm not a ludite.
Hard tail or rigid ? See above
Big tyres 2.35+ or small tyres anything up to 2.35? 2.35
Thick tubes or small tubes for the frame? Appropriate tubes. If I can see the FEA, so much the better.
Low BB or high BB? Low
Posted : 08/02/2009 3:07 am
What is the right amount of travel on a aggressive hard tail? - 130mm
Best frame material for a hard tail? - aluminium for agressive stuff, steel for longer rides
Preferred top tube length? 23 inch ish
Preferred frame size? - 17 to 18 inches
Preferred wheel size front and rear? - 26 inches
Slack ,steep, or somewhere in the middle. -(Head tube angle) - slack
How much would you pay for a highly specked aggressive hard tail? - 1000 max
Singlespeed or geared? either but for aggressive stuff probably geared is best
Hard tail or rigid ? hardtail
Thick tubes or small tubes for the frame? - what's needed with no pointless pose tubing
Low BB or high BB? Low and a bashring
Posted : 08/02/2009 8:56 am
What is the right amount of travel on a aggressive hard tail? 14-150mm
Best frame material for a hard tail? 853 steel
Preferred frame size? 17"
Preferred wheel size front and rear? 26"
Slack ,steep, or somewhere in the middle. -(Head tube angle) 67'
Singlespeed or geared? geared
Thick tubes or small tubes for the frame? thin
Low BB or high BB? low
Posted : 08/02/2009 9:08 am
why not ask people to fill in a form > [url= http://googledocs.blogspot.com/2008/02/stop-sharing-spreadsheets-start.html ]google docs forms[/url]
Posted : 08/02/2009 9:28 am
What is the right amount of travel on a aggressive hard tail? [b]140mm[/b]
Best frame material for a hard tail? [b]Steel - Cromoly[/b]
Preferred top tube length? [b]22"[/b] [i](But i've got a really long body with short legs, 6'3" with a 32" inside leg)[/i]
Preferred frame size? [b]L or 19"[/b]
Preferred wheel size front and rear? [b]26" both ends[/b] [i](But I would like to try a 29er at some point as I am tall)[/i]
Slack ,steep, or somewhere in the middle. -(Head tube angle)[b]Steep (ish)[/b]
How much would you pay for a highly specked aggressive hard tail? [b]upto £1500[/b]
Singlespeed or geared? [b]Geared - definately[/b] [i]Too many "Big" mountains in this bit of Wakes[/i]
Hard tail or rigid ? [b]HT[/b] [i]But I'm loving my rigid cross bike at the moment[/i]
Big tyres 2.35+ or small tyres anything up to 2.35? [b]2.4[/b]
Thick tubes or small tubes for the frame? [b]Small tubes[/b]
Low BB or high BB? [b]Low BB[/b]
Hope this helps, good luck with your GCSE's. I built a Full susser (really badly) for my A Level "Design Tech" and my mate built a Hydraulic Disc brake, back in 1994 !!!
Posted : 08/02/2009 10:52 am
