Anyone fitted, or tried to fit, a Gamut Bashguard to Truvativ Firex cranks?
I have been running a Truvativ bash for a year but it's recently cracked out from ALL the bolt holes.
Come on guys and gals! Help a man out?
I run a gamut on an 9 speed XT
I would have thought it would be ok on a truv
I ran a A gamut on a Shimano SLX chainset. The tabs on the bash ring just needed a slight bit filing of them for it to fit on the arms.
Dont see why not, assuming the cranks are 104bcd. I have a Gamut p30 fitted to some XT cranks and the only issue i had was i damaged the chainrings bolts when removing an old damaged bash and the ones i bought to replace where too short at the back so ended up using the shimano back piece and the allen headed bolt from the new ones, guessing the Gamut ring is a bit deeper than some others as i had an FSA bash that didnt have that issue.
HTH
Cheers fellas. Keep your fingers crossed for me.
You must log in to post.
