Freehub is knackere...
[Closed] Freehub is knackered....
[#2870393]
... I think. Following a very wet and gritty ride last weekend, after this weekends jaunt I noticed an odd clicknig noise coming from the rear wheel, and that my pedals had started turning when wheeling the bike about. Then, on my commute today, there was a distinct deterioration in engagement, with cranks often spinning up to half a revolution before any drive engagement.
So, three questions:
1) Am i correct in assuming the the freehub is knackered?
2) If so, is it repairable? It's on a Deore XT (FH-M756) hub
3) If it's not repairable, can you swap different brands/"levels" of kit (i.e. standard Deore instead of XT)? For example, would [url= http://cgi.ebay.co.uk/SHIMANO-DEORE-REPLACEMENT-FREEHUB-BODY-M530-HUBS-/380340442515?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item588e0e9593 ]this[/url] fit, or is it specifically for M530 hubs?
Thanks in advance!
Posted : 20/06/2011 6:53 pm
Probably not repairable, but a Deore one will go on fine. Might be as cheap to buy a whole Deore hub & stick the new bearings & cones in while the axle is out. (Has to come out to get it off, I think). You'll need cone spanners.
Posted : 20/06/2011 6:58 pm
Could try taking it off, removing the seal at the back and giving it a really good flush through with WD40 followed byu further flusges with oil. Could also be knackered. Deore freehub £ 21 from CRC
http://www.chainreactioncycles.com/Models.aspx?ModelID=1161
Posted : 20/06/2011 7:02 pm
I bought a full hub from wiggle as there wasn't much difference in price. Was dissapointed how long the original lasted.
Posted : 20/06/2011 7:38 pm
