Fox FIT Upgrade...w...
[Closed] Fox FIT Upgrade...worth it?
 nuke
[#2245477]
As per here...
http://www.mojo.co.uk/getfit.html
So for £199 including a service, my 2009 TALAS RL forks would be upgraded to TALAS RLC with FIT...worth the extra money over a standard service?
Posted : 02/12/2010 10:28 am
 thv3
Also interested.
Planning on sending off my 2009 Van 36R in the new year to be upgraded to the Van RC2.
Will be due a service anyway so seems a no brainer.
Posted : 02/12/2010 10:40 am
well as long as your forks are in good nick and you want to keep them for the next few years, its basically like having a new pair of forks....
im not keen on the low speed compression thing, its more faffing around thats why i like the RL's, but ive heard the FIT damper is MUCH better than standard cartridge in the RL's, no proof of this i have ridden on FITS and they seem alot more bump sensitive, which is pretty neat..
that said my rl's are a hell of lot more plusher and generally smoother than my old 09's rlc's without Fit cartridge...
if a service is £100 at mojo or there abouts, then its defo worth it, even as a resale point of view for the future if its still on offer in a few months i may consider it..
 nuke
Thanks for that. TBH I've been very impressed with my Fox Talas forks as it is over my RS forks so I did wonder if it would be worth it but sounds like it is.
Posted : 02/12/2010 12:03 pm
Doesn't the FIT cartridge also save some weight? OK not much but it might be another reason to have it done.
I have the FLoat RLCs and the low speed compression is something i do make use of and benefit from. I don't use the lockout though.
Posted : 02/12/2010 12:07 pm
 nuke
Yeah, bit of a weight saving is also a good thing.
Also, from reading another thread and if I understand correctly, more oil goes in a FIT leg so there is more oil to lubricate which has got to be good with Fox forks and their reputation for stanchion wear.
Posted : 02/12/2010 2:45 pm
Go for it
I have used the R cartridge's in my bikes, but when I got the new 2011 RC2 inverted damper the fork was totally transformed, much more controlled, no spiking...
Remember they will service, touch up the paint and new stickers... so a said a new pair of forks...
Posted : 02/12/2010 3:03 pm
