Formula/Shimano com...
[Closed] Formula/Shimano compatibiliy?
[#3643832]
Just bought to Formula K18's to replace my Shimano M445's.
I will be keeping the same rotors.
Do i need new mounting brackets lads or are they compatible ?
Cheers.
Posted : 04/02/2012 6:35 pm
Should bolt straight on as long as your existing calipers are post mount.
Posted : 04/02/2012 6:42 pm
I never know the answer to that..
It's a 2011 Giant XTC 29er.
http://www.giant-bicycles.com/en-GB/bikes/model/xtc.29er/7876/45527/
Posted : 04/02/2012 6:48 pm
Will be fine.
Posted : 04/02/2012 8:36 pm
Thanks
Posted : 04/02/2012 8:40 pm
I seem to recall that the K24 (and K18 - they're the same) calliper piston body sticks out quite a way below the mounting holes and the 160mm formula disk mount is designed to accomodate this. The shimano mounts may not fit.
Posted : 04/02/2012 8:53 pm
Mine are all fitted on Shimano mounts (203 and 108 fronts, 160 and 180 rears). Not all Shimano mounts are the same mind.
Posted : 04/02/2012 9:28 pm
My K24's dont fit avid of shimano rear adaptors on a 160 rotor without LOTS of spacing..Just had to lash out £17 on a formula adaptor 😥
Posted : 04/02/2012 9:36 pm
Straight on, perfect 🙂
Posted : 07/02/2012 8:36 pm
