Eliminating Brake J...
[Closed] Eliminating Brake Judder
 Tim
[#242730]
Hey all
Been suffering from annoying, and getting to the point of dangerous, brake judder on my crosser.
Grab a handful of front brake and what power you get from the tektro frogleg brakes is wasted by horrid judder - you can actively see the fork flexing quite a lot! I cant really remember it being like this from new, so i presume it has developed as the pads have worn
Tried it with the straddle low, the straddle high, adjusted the toe-in - most things really. It could well be the forks, but i'd rather NOT spend money on forks if i dont have to 🙂
Any tips?
Thanks!
Tim
Posted : 25/01/2009 5:03 pm
 Joe
Change the pads, this has to be your first port of call. If that fails change the canti. If that fails the fork. Sorry.
Posted : 25/01/2009 5:09 pm
Had the same problem with some Magura Julies-every time the pads heated up when they were worn-switched to more continuous edge discs ie no wavy rotor or V* cutout and hey presto no vibrations.
Posted : 25/01/2009 5:11 pm
Had the same bother, not frog-legs, shimano cantis. I changed the headset-a cheap and nasty one- as the cups were flexing under braking! It was nearly unridable, put a richey WCS one in problem solved!
Try the pads too
It's a Focus CX bike
Posted : 25/01/2009 5:15 pm
 JoB
if your forks have a hole for a fork-mounted cable-stop then put one of them on
Posted : 25/01/2009 5:18 pm
As Jo suggested - ended brake judder for me.
Posted : 25/01/2009 5:49 pm
 Tim
ah ok cool, i'll try the pads and it has a hole so i'll try one of the hangers too.
Thanks!
Posted : 25/01/2009 6:14 pm
If you have had it for a while, another consideration is that the brake posts may be worn.
Posted : 25/01/2009 7:21 pm
Sorry to resurrect an old thread but brake judder has blighted me recently.
I've tried to find a fork mounted cable hanger as shown by JoB above but I can only find them in stock in the USA and they don't want to ship them to the UK. I came up blank on Ebay and general Google searching as well.
Does anyone know where I can get one? Am I just really crap at searching?
Thanks,
Jim.
Posted : 05/09/2010 1:26 pm
this is the one I have on my Jake the Snake :
[url] http://www.petracycles.co.uk/product_info.php?language=en&currency=GBP&products_id=57966&source=googlepbs [/url]
works a treat
Posted : 05/09/2010 1:30 pm
You can get one from [url= http://www.spacycles.co.uk/products.php?plid=m2b0s101p1809 ]Spa Cycles[/url].
Posted : 05/09/2010 1:32 pm
I think I've got one. Drop me a line (email in profile) and I'll have a nose around for it.
Posted : 05/09/2010 1:35 pm
Thanks for the info folks. Going to order one from Spa cycles - only 6.50 inc pandp.
Thanks for the offer bikewhisperer. Hang on to it for for some other deserving soul who suffers the dreaded judder.
Jim.
Posted : 05/09/2010 8:56 pm
Any decent LBS will sell one
Posted : 05/09/2010 8:58 pm
