Finishing off the bike build (On One 456), which seems to have gone pretty well considering, but I’m not totally convinced by the way that the cable to the SLX front mech is fitted. Basically the cable goes from the top tube, through the lug on the down tube and, rather than following the down tube down, the cable skews off at quite an angle to the fixing point on the front mech (the allen key bolt). I can’t see, but is there some other way that it should be fitted (e.g. round some sort of pulley wheel, etc.) or does the cable go directly to the fixing point?
By the way, have taken it out on it’s maiden voyage to work this morning and it’s lurvely. Will get some pictures up later – as if you lot aren’t sick of seeing yet more images of On Ones!
Ta
