does this sound rig...
[Closed] does this sound right (concrete footing mix quantities)
[#3816847]
for a 11m long, 45cm wide and 20cm deep footing i'll be needing:
15 x 25kg bags cement
2.2t of all in ballast
(and a cement mixer!!!)
for a 1:5 mix
many thanks
Posted : 28/03/2012 2:18 pm
That's about a metre, a bit heavy on the ballast I think. I'd order two of those maxi bags, about 1600Kg. Unless you want plenty rather than being a little short.
Posted : 28/03/2012 2:45 pm
Don't listen to me, google for a concrete calculator there are loads.
Posted : 28/03/2012 2:46 pm
Just get a barrow mix wagon in, they'll only give you what you want, no messing about mixing, consistant mix type/slump and no waste or shortage of materials.
Sure they might be a tad more expensive but worth the extra imo.
Edit - Your looking at about 1 cube which is around £125
Posted : 28/03/2012 10:03 pm
Yep +1 for Mixamate or similar.
Posted : 28/03/2012 10:05 pm
Don't attempt to mix that yourself, its really not worth the hassle or effort. Just get it delivered, costs way less than you think. My last lot cost £65 a cube
Posted : 28/03/2012 11:23 pm
