Crown race removal/...
[Closed] Crown race removal/refit- top tips without the proper tool?
 TomB
[#3736706]
Hi all. I've got to remove a couple of crown races off forks for swapping round purposes. I don't have "the tool" to do it, so before I stick a screwdriver through my steerer or something else silly, any top tips for this job?
Ta
Posted : 03/03/2012 8:32 pm
I always used a piece of wood, but if you are stuck, pinch an old wooden spoon out of the kitchen...
Posted : 03/03/2012 8:33 pm
Screwdriver. Mallet. Done.
Flat head screwdriver, hammer, easy does it!!
Repeat for fitting...Job done 8)
Posted : 03/03/2012 8:34 pm
Big screwdriver here also. Tapping either side. I usually fasten a zip tie or peice of string through the headtube to catch it when if drops out.
Posted : 03/03/2012 8:35 pm
A vacuum extension tube is the perfect size for fitting over the steerer to tap the race back on. For removal use something sharp like a stanley blade to start it off then use a screwdriver
Posted : 03/03/2012 8:38 pm
Remove with a chisel, then a screwdriver and hammer.
Fit with a lump of wood and a hammer!
Yep, screwdriver and rubber mallet. May take a while if it's a really tight fit but should do the job.
Screwdriver is fine, but it's easy to gouge the crown if you're heavy handed. Just take your time - maybe use a smaller, 'sharper' screwdriver to get it started then a larger one - slow and methodical round the steerer and the race will lift off nae bother.
Posted : 03/03/2012 8:39 pm
 TomB
Cheers all, suitably reassured. (Scurries off to garage to start hitting things with big mallet....)
Posted : 03/03/2012 8:54 pm
Maany LBS inlcuding mine will pull the race of for you for free. I would recomend doing it this way as I have seem many crown seats with srewdriver marks and those need facing. Fitting the new race with a piece of wood and a hammer will do no harm. The proper parks tools will set you back about £180 (puller and crown race setter) + a fiver for 12mm threaded bar and washer + nuts to make a press.
Posted : 03/03/2012 9:20 pm
Step and away from the bike and do a little bit more research than wood and mallet answers.
Remove - stanley blade and then a series of increasingly thicker screwdrivers plus gentle tapping - never fails. Slowly slowly catchy monkey.
Install - White plastic waste pipe - perfect fit and softer than anything it will meet- so no damage done. Good tap and installed.
Total cost £2 and it works everytime.
Hope this helps - Wally.
Posted : 03/03/2012 9:56 pm
Of course the easiest way to get it back on is to cut a nice little slot in the race. No need for any tools at all once that's done
e.g.
Posted : 03/03/2012 10:04 pm
I have a special chisel. I never worry too much about cosmetics on the crown of a fork as my special chisel will leave its mark. Ho hum.
+1 for white plastic pipe to install. Put it over the steerer and whack into the garage wall. That always works fine.
Posted : 03/03/2012 11:11 pm
