Cotic Soul advice p...
[Closed] Cotic Soul advice please
[#3810532]
Hi im embarking on my first build but am in need of a little advice, i have just purchased a cotic soul frame and im planning on building it up with slx components, for starters what gearing e.g. 2x9, 2x10, 3x9 or 3x10?
also which models of slx derailleur would i need for the soul?
cheers
Posted : 26/03/2012 4:36 pm
Totally personal preference - what do you use now? I ran 2x9, then 1x9, now 1x10. Others use 3x9, 2x10 and 2x10. You need a top pull front mech with the shims to fit a 28.4mm seat tube.
Posted : 26/03/2012 4:42 pm
well i will probabley go 3x9 as its what i usually ride also doesnt have to be slx if anyone has any better suggestions? model numbers would be a bonus to
cheers
Posted : 26/03/2012 4:46 pm
You could run any of those gear setups on your bike no problem. It really depends on your commonly ridden trails, fitness, personal prefernce etc. as to which is 'best' for you.
I personally have a 2011 3 x 10 SLX groupset on my Soul and the good news is that it has been excellent. Living in Scotland I do choose to tackle some steep climbs and I am certain that the 3 x 10 setup was the correct choice. I use the 22 and 32 rings quite a lot and the 42 a bit. I like to keep my chainline pretty optimal and shifting onto the 22 regularly helps me do this. I also like to spin a faily high cadence in the saddle to climb, rather than stand a power up things.
The seat tube is 28.6mm OD but the Shimano front derailleurs come in one size - 34.9mm. You therefore need to use a specifice spacer to space the clamp down for smaller seat tubes. When I ordered my derailleur it did not come with any spacers, I therefore tracked down of my own from a mate who had some spare.
Hope that helps a bit!
Posted : 26/03/2012 4:48 pm
Posted : 26/03/2012 5:13 pm
My advice would be to go for 1x9 or 1x10 with a chainguide.
Posted : 26/03/2012 7:13 pm
Have a look at rosebikes.co.uk for cheap Shimano kit.
Posted : 26/03/2012 7:25 pm
1x10 sounds like a viable option what crankset would you go for with that set up?
Posted : 26/03/2012 7:32 pm
I bought this:
http://www.wiggle.co.uk/shimano-slx-m660-front-derailleur-for-triple-chainset/
and used this adaptor:
http://www.wiggle.co.uk/shimano-m510-band-adapter-286mm/
If you use the top pivot version:
http://www.wiggle.co.uk/shimano-slx-m661-front-derailleur-for-triple-chainset/
then the front mech mount interferes with one of the bottle mounts on the frame as evidenced here:
Posted : 26/03/2012 7:34 pm
It's a lovely bike - put some gears on that will get you up the big hills without having to suffer the humiliation of pushing. Fits a 120mm bolt-thru fork, some nice wheels (stans tubeless) and a pair of Hope Minis (or whatever they call 'em these days) You'll be laughing!
Posted : 26/03/2012 7:45 pm
