Converting SLX cran...
[Closed] Converting SLX crank to a "Racing" double
[#3071856]
I was going to buy the new XT 28t/40t cranks for racing on next year and converting my Anthem to a 2x10 rather than the tired 3x9 I have on it now.
But I was wondering is there anything to stop me sticking a 28t granny on my SLX and a 40t middle ring?
Currently I have a 26t and 36t and haven't noticed either being tight on chainstay clearances or anything so I assume there is no big deal about making the change?
Who sells nice big chainrings then???
Posted : 22/08/2011 10:30 am
Nothing stopping you doing that at all, assuming you have the clearance.
You'll need narrow chainring bolts and you may find that a double specific front mech is more reliable at stopping chaindrop though.
Posted : 22/08/2011 10:37 am
If you stick with 9 speed just use your current front mech, if you go 2x10 then a 10 speed XT double one may be marginally better, I personally never had problems with that combination and a normal triple front mech.
TA Chinook chainrings get my vote, Starbike.com are generally much better value than the UK sellers, and have better stock.
Posted : 22/08/2011 10:42 am
I was just about to post about narrow chainring bolts but was beaten to it!
As for chainrings, check out Middleburn.
Posted : 22/08/2011 10:43 am
Not my experience unfortunately - I found that no matter how I set up my front mech (using 24/36 and an XTR 9speed triple front mech), the chain would come off 5-10 times per ride. An SLX double front mech stopped the problem immediately.
Posted : 22/08/2011 10:45 am
velosolo for chainring bolts,
i can personally vouch for middleburn rings, they last ages and are reasonably priced.
Posted : 22/08/2011 10:48 am
I already have narrow bolts, used to run these as a double on the trail bike.
Cheers for the chainring advice, can only see 4 bolt middleburns up to 26t on the granny, will check out those other options.
Posted : 22/08/2011 10:50 am
That's because the SLX double front mech has a 'tighter' curve to suit smaller rings - which you were using. If you're using larger rings the curve on the SLX mech is too small, you're better off with a normal triple front mech.
I ran a normal triple one for 3 years, never once dropped the chain.
Posted : 22/08/2011 11:02 am
I run 28/40 Specialites TA rings on my M970 XTR canks, no problems. I also use an M950 (triple) XTR front mech with no issues.
Posted : 22/08/2011 11:05 am
I think this is correct - pretty sure I read the SLX double is only designed to go up to 36 teeth as the largest.
Posted : 22/08/2011 11:33 am
Middleburn ring compatible with 10 speed? or is that a whole different flame war?
Posted : 22/08/2011 1:05 pm
