Building a shed
[Closed] Building a shed
[#3998777]
I am putting a very small shed (3x4) at the side of our patio. I can't decide if I should stand it on pressure treated timber, or if I should put some more paving slabs down. The slabs are more work of course.
Posted : 22/05/2012 10:28 am
As long as its flat it should be ok, if you're going to paint it, do it before bolting it together, makes it look much neater,
I put this up last week, beach hut stylee..
Posted : 22/05/2012 10:31 am
I would stand the legs on something if its going onto the grass. Just a small slab under each foot should be enough.
But put some slabs/path down in front of the entrance.
Posted : 22/05/2012 10:34 am
You can just lay paving slabs on earth for a shed - no need for hardcore etc, mine were just laid on the lawn and it's been fine for years.
Posted : 22/05/2012 11:28 am
The trick is to get air under it to stop it rotting.
Timber definately easiest. Make sure you treat underside of shed before building.
Posted : 22/05/2012 4:12 pm
you'll need the pressure treated timber whether you use slabs or not.
Our beach hut is on some 'sacrificial' timbers;
Posted : 22/05/2012 4:13 pm
