I'm moving from a 73mm BB shell to a 68mm BB shell frame, with the above cranks.
Is it just a case of putting some spacers on the drive side behind the cups as per shimano, hope etc...
www.youtube.com/watch?v=FT4qzevaOWo
never heard of spacers being used?
All road frames should be 68mm width if english threaded...??
+1 road bbs aren't 73mm unless you're fitting ut cranks to an mtb.
Cheers all
Yes, it was a case of tape measure fail, on the plus side at least the cranks fit the new frame..!
You must log in to post.
