Any shoplifters on ...
[Closed] Any shoplifters on here tonight
[#2262956]
A couriers just delivered a new thermal top I'd ordered for my son and they've left the security tag on it. So can anyone tell me how to get it off without doing any damage.
Thanks.
Posted : 07/12/2010 8:50 pm
magnet
Posted : 07/12/2010 8:52 pm
Some strongish magnets? Is that not what they use in the shops?
Posted : 07/12/2010 8:53 pm
Take it shopping with you with the receipt and ask the checkout people very nicely.
I had to do this with a set of shorts that I bought while away from home and had the tag left on.
Posted : 07/12/2010 8:55 pm
Hold the pin as if you are trying to pull it out and bang the plastic side against a hard service repeatedly - the pin should come out it you get it right.
Best of luck
Winona
Remember Neg and his urban sports?
Just an idea next time you're down the shopping mall 😀
Posted : 07/12/2010 9:02 pm
Depends on the tag. Best take it to a shop and ask as someone suggested. Then ask for the tag back and slip it into your wife/friends/strangers bag/pocket and chuckle as they get searched by secuirty.
Posted : 07/12/2010 9:06 pm
I've never spiked anyone's shopping bag with a security tag, oh no. I've never accidentally rested anyone's credit card on the tag removal magnet either, despite how unpleasant they've been.....
Posted : 07/12/2010 9:09 pm
 Kato
I managed to get one by using a drill on the side with the cone. You know? The pointy bit on the disc
When the pin goes into this it's held from coming out by 4 ball bearings. You'll need a cone shaped magnet to get them all moved upwards away from the pin.
If you drill the top of the cone away you'll eventually make a hole big enough for the ball bearings to fall out thus releasing the pin
HTH
Posted : 07/12/2010 9:10 pm
Depends what sort of tag.
Generally, it's a burn the plastic end open and then twiddle with the the bit inside to get it off.
Only disadvantage to this is if it's an ink pack, however if it goes off, straight into hot water and you can save the item.
Note:never shop lifted in my life, but had the experience of spending time with a heroin addict and friends when he was trying to come clean.
Posted : 07/12/2010 9:11 pm
If you do the above, i'd soak the item in water beforehand, at least you stand half a chance of removing any ink then.
Posted : 07/12/2010 9:37 pm
Thanks all. It'll be a pain to get to any shops that'll have a tag remover so I may go with the drill/general violence although it will now be guided with the knowledge of how it works.
Posted : 07/12/2010 9:51 pm
Why don't you just cut the material around the tag for an additional pocket? Or cover the tag with a couple of bags before prising the fastener off?
Posted : 07/12/2010 9:56 pm
I used to work in a clothes shop and, I'm told, [s]we[/s]they could remove the tag with a screwdriver, pliers and the likes. My mate, however, used a large speaker's magnet.
Posted : 07/12/2010 10:48 pm
The company need to be informed so that they can remind their staff. However, I used to work for a high street retailer and, believe me, it was very easy to forget to remove them. We semi-regularly had customers returning items.
What I don't understand is how the package did not set off the alarm when it left the warehouse.
Posted : 07/12/2010 10:59 pm
Winona
Heh heh, gave me a chortle
Posted : 07/12/2010 11:08 pm
avdave2 - Member
Thanks.
POSTED 2 HOURS AGO # REPORT-POST
How very odd! My wife *bought* some clothes from a kiddies shop earlier today and and pair of trousers had the tag on (Jojo Mamen Bebe so bloody expensive). I wrapped the ink part in a sandwich bag then prised the two parts apart with a kitchen knife. Took about 5 minutes of faffing.
Posted : 07/12/2010 11:15 pm
Stihl saw! Works on virtually anything! My favourite multi tool!
Posted : 07/12/2010 11:22 pm
Not all mail order operations have warhouses. I've been in JE James in Chesterfield and seen the mail order man picking items from the shop displays.
Posted : 07/12/2010 11:33 pm
Bung it in the freezer overnight, then hit it with a lump hammer
Posted : 07/12/2010 11:57 pm
I've heard of someone just cutting through the pins with a large pair of dressmaking scissors.
Posted : 07/12/2010 11:59 pm
[exceited small child mode] ^^^^^^^^^^^^^^ that one only problem I see is having ot wait a night to attack it with a hammer
Posted : 08/12/2010 12:02 am
Can't see it being much of a punishment for their nastyness TBH, it seems to make absolutely no difference to them, especially in the days of chip and pin. I swiped an almost-expired card of mine on a hard disc head magnet for about 5 mins (UBER powerful) and it still swiped just fine. God knows how.
Posted : 08/12/2010 12:11 am
