I have another direction of thought now in why I am not happy with my disc brakes: I have only ever owned two pairs, the first was Hope Mini’s and then about three years ago I switched to Formula Oro Biancos. My complaint about both is pad wear, I get through Pads Soooooooooo quickly. I live in a VERY hilly area, a small ride will have minimum 500 metres descent and of course, where possible, I make as much of this single trail which I believe is heavier on the pads.
Another factor to pad wear is that I am a fairly heavy rider (85 – 90kgs, depending on what I have eaten / drunk the previous couple of weeks).
Instead of thinking like a weight weinnie (exc spelling!), should I be thinking more on the lines of a brake setup somewhere between downhill and light weight? If so, which brakes fall into this category, my Oro pads are pretty small, I guess I need a setup with more meat on the pad??
I have of course tried everything to improve the wear on my current setup, bedding pads in, new rotors, different compounds etc etc.
