A wee video from ye...
[Closed] A wee video from yesterday
[#2353075]
Blue skies, quiet trails, grippy snow. 😀
Posted : 10/01/2011 10:53 am
There's either a weird angle on that or you are very, very thin
Posted : 10/01/2011 11:02 am
Weird angle 🙁
Was out round Mugdock for a blast yesterday also. Recognised some of the trails, there were others areas I didn't though. Should tie up for a run one w/end and you can show me some more of the off piste stuff!
Posted : 10/01/2011 11:35 am
More than happy to show anyone around. Even I managed to find new trails yesterday that I'd never been on before! God bless tracks in the snow.
Posted : 10/01/2011 11:37 am
Bob
Drop me an email, cant see your in your profile
cheers
Posted : 10/01/2011 11:46 am
Done
Posted : 10/01/2011 12:01 pm
Nice wee vid , made all the better by Radiohead . well done.
Posted : 10/01/2011 12:40 pm
Your meant to pelt it past the camera then rest out of shot. That was you can convince everyone that your actualy really fast! 😛
Good vid nontheless. Has your editing software stretched the aspect ratio a bit though?
Posted : 10/01/2011 12:43 pm
good vid, re-upload on vimeo at 16x9 instead of 4x3 and you should be sorted for aspect ratio correction
biked up there last week in between the snow in the rain - think you had the better conditions
Posted : 10/01/2011 12:57 pm
Cheers.
Was a 'mare trying to edit it but I used Windows Movie Maker. It was shot on a Toshiba Camileo S20. The early sections were shot in VGA before I noticed and switched to 720 HD. Don't know if it's the camera or movie maker
Posted : 10/01/2011 12:58 pm
Bob - looks good, I couldn't get out for the usual Sunday spin with GMBC yesterday am due sick kids. I had been 'hoping' it was all icy and unrideable though !!
Posted : 10/01/2011 1:00 pm
If today's commute is anything to go by, it'll be back to icy and unrideable. Came off the bike this morning as I cycled through Queens park. Solid, super slick ice everywhere.
The ice was still there yesterday but it was covered by grippy snow but the thaw was setting in quite heavily by the time I left about 2pm. I suspect the freezing temps overnight will have turned it back into a massive skating rink 🙁
Posted : 10/01/2011 1:17 pm
Bob, when you go to save it on movie maker (publish movie) and you come to the movie settings screen click on;
- more settings button and then
- select WMV - HD - 1280 x 720
That should sort out the perspective issues.
Posted : 10/01/2011 5:57 pm
Cheers, I'll try that when I get home.
When you're outputting the video in WMM, there appears to be a massive gap between the best quality format (which was 750 meg) versus the next available which seemed to max out at 50 meg.
I went for the full quality version then discovered vimeo wont accept files over 500 meg, and youtube uploads kept failing so I had to re-run the 750 meg file through WMM and convert it to a much lower quality version to upload it.
Am I missing something or is there a gap between the file outputs?
Posted : 10/01/2011 6:09 pm
which version of WMM are you using? Is it the one you get with XP and Vista (same version) or the newer one that you get with Windows 7?
And what file format does your camera shoot in? and can you import it directly or do you convert to avi and then import?
Posted : 10/01/2011 6:31 pm
Still on XP so it's the version it came with. Camera outputs AVI files
Posted : 10/01/2011 6:53 pm
Hmmm... strange.
I use a GoPro HD and with MSWMM I convert to avi and then edit. Can get a HD res movie of say 8 minutes which is about 350mb.
Just experimenting with Adobe Premiere Elements at the moment and that seems to save even larger files.
But to answer your question, if you want widescreen (which you do to make the perspective correct) then you will get large file sizes although on that settings page there is one other 16:9 setting which isnt HD so may save smaller files but I've never used this so it may be worth trying it to see the difference.
Posted : 10/01/2011 7:06 pm
