12/36 cassette........
[Closed] 12/36 cassette..............anyone
 ton
[#1373253]
run my ventana with a 22/32 on the front, with 12/34 cassette.
like to spin so was gonna try a 12/36 cassette.
anyone running one yet.
Posted : 01/03/2010 11:07 pm
wow 22:36 @ 90 rpm is an astonishing 4.3mph.....
Posted : 01/03/2010 11:09 pm
i'd rather get off and walk at that point...
Posted : 01/03/2010 11:11 pm
 ton
32/36 is what i want it for.
Posted : 01/03/2010 11:12 pm
Look at MTBR 29er forums, plenty of people using them. Alternative is Middleburn cranks with 20/30/40T rings.
CRC have stock of the cassettes btw.
Posted : 01/03/2010 11:13 pm
Might be worth it for a 1x9 setup. Yes - I'm thinking of a 30T front for my 1x9 setup
you might have to change your rear mech. Shimano recommends that this cassette is only compatible with Shimano Shadow type rear derailleurs. We've run it successfully with a basic Deore (non-shadow design) with the B-tension screw all the way in. its bloody huge. get a road bike if you want to spin like that.
Posted : 01/03/2010 11:14 pm
 ton
running slx, so it should be ok??
Posted : 01/03/2010 11:17 pm
32:36 more or less = 22:24
6.3mph vs 6.4mph and a better chainline to boot
I'm not sure what you mean. How will a road bike get you up a steep muddy trail?
Posted : 01/03/2010 11:18 pm
Tony, the GF has one on her bike as following a hip operation she has to spin everything / everywhere. Rear mech is a std deore, just enough clearance. I reckon it'd be great on a 1x9 29er.
Stuart
Posted : 01/03/2010 11:19 pm
1x9 i see the point -2x9 little point unless its an XX style set up with a gert jump between gears
Posted : 01/03/2010 11:21 pm
Cross style - bike on the shoulder and run. Hup, hup hup..! 😀
 ton
ordered....
stuart, emailed you asking for deatails of the welsh thing.
have you got any...........details that is....... 😉
36T cassette on a 29er is the similar to a 32/34T cassette on a 26er - whats the problem with that 🙄
Posted : 01/03/2010 11:22 pm
Got your email Tony and replied ... I'll send it again from a different account, must have got lost. Let me know if it comes through.
stuart
Posted : 01/03/2010 11:24 pm
Ton - have you seen the Action Tec Ti cassettes http://www.actiontec.us/ticog.htm - 11/ 36T or up to 39T !!! a bit expensive though, but much lighter than a Deore Cassette.
Posted : 01/03/2010 11:34 pm
I thought this cassette chewed up the inside edge of the hub splines?
I looked into going this way a while but decided against it for that reason. Can't remember all the details now
Posted : 02/03/2010 12:08 am
