Home Forums Bike Forum Zero stack headset for 44mm headtube……
Viewing 11 posts - 1 through 11 (of 11 total)
  • Zero stack headset for 44mm headtube……
  • rickon
    Hi Chaps,
    I’ve seen the CK one, but does anyone else know of a 44mm headset, for a tapered fork which is Zerostack?
    Cheers for the help!
    Ricks
    wrecker
    Cane creek 40 series or hope.
    I replied to your mail BTW.
    passtherizla
    Hope pick and mix will have something too. Think it’s top cup 2 bottom cup B. for 1.1/8 steerer you might have to use an external if you are using tapered.
    RustyMac
    Hope pick n mix 2, H cups
    Nukeproof Warhead 44IETS Headset
    passtherizla
    Sorry missed the Tapered steerer bit…
    The H cup from hope is traditional external cup, not zero stack though.
    geetee1972
    I’m pretty sure you can’t so zero stack on the bottom of a 44mm tube with a tapered steerer. You need a 56mm lower part for that.
    passtherizla
    Think geetee has it.
    RustyMac
    For a tapered steerer to work in a 44mm headtube you need to have an external lower cup, if you do the basic maths it can not work any other way.
    nealy
    Indeed, zero stack top but need external lower.
    Superstar Components do one for £28 that comes with two fork crown races for standard and tapered steerers
    http://superstar.tibolts.co.uk/product_info.php?cPath=25&products_id=539
    rickon
    False alarm! Some pooface bought the last large sultan frame just as I was getting my card out. FAIL.
    m1nt5auce
    Hi, I had this very same problem and there is in fact a zero stack headset for running a tapered fork in a 1.5″ headtube. You need an FSA Gravity 2 headset. It uses a sealed bearing up top and very small caged bearings in the lower to allow them to be incorporated within the headtube. It’s not without downsides; it’s pretty heavy and the bearings will wear faster than sealed (I had to replace after 6 months), but a bag of 50 was 3 quid! Hope this helps. http://www.shinybikes.com/gravity-by-fsa-gravity-2-headset-tapered-steerer-130-0020n.html
The topic ‘Zero stack headset for 44mm headtube……’ is closed to new replies.
