As per my original post..
I’ll go see if the local key cutter wants to do for me
For some reason I thought there might be a restriction on who can supply them, hence ordering online.. I was wrong, local timpson’s had it cut in under 30 seconds
We charge for local deliveries that have a small value less than £25 as the margins make it pointless.
That’s absolutely fine I understand that, as long as you say that up front, advertising a key for £8 then charging £19 at the till is a different matter.
Some companies just taking you for all they can.
Yep, squire is amongst them
