Home Forums Bike Forum Why is my rear wheel creaking?
Viewing 15 posts - 1 through 15 (of 15 total)
  • Why is my rear wheel creaking?
  • thered
    I have had hub bearings replaced, freehub bearings replaced, greased the outside of the freehub body, tightened the rotor.
    It’s definitely the wheel as I have tried another which doesn’t make a peep
    hatter
    How old is the wheel? May be time for a spoke retensioning.
    kimbers
    This +100. Put my (creaky) wheels in for a true, turns out my tweaking to keep things straight had messed with the spoke tension
    thered
    2 years old
    Onzadog
    Possibly the freehub body was cracked during the pressing in of the freehub bearing.
    rone
    I’ve just spent the last year trying to solve a creak – not BB, refitted lots of times. New crank etc. Driving me crazy.
    Sometimes it can be the seat but you can figure that out by standing up.
    In my case it looks like it’s the rear axs gx derailleur.  The pins that hold it together seem to have gone really dry or something related to that. I can replicate it by pull it away from the bike.
    When I pedal hard it pulls the mech body and it sounding exactly like a wheel issue.
    Can you switch the cassette to the quiet wheel? Some cassettes are trouble like the sram pinned versions of 11 speed etc.
    Stevelol
    The spokes may be unequal in tension.
    Squeeze each pair of adjacent spokes on one side of the wheel, compare how stiff they feel compared to another rear wheel that’s in good condition.
    The squeaking is from the spokes rubbing together where they cross over each other. However the sound is quite different to a usual creak like a loose bolt or dry or worn bearing.
    hightensionline
    Spokes rubbing where the pattern crosses over? Dab of chain oil on that point if so.
    andyxm
    This will sound very random, but I had a creak that happened mainly going uphill, slightly re tensioned the rear mech and it was sorted.
    Onzadog
    Cassette lock ring not tight? Or depending on cassette, little plastic anti squeak spacer fell off when refitting?
    Scienceofficer
    My latest mystery creak turned out to be the B – tension screw on its stop!
    Freester
    One of my spokes nipples creaked once. Try rolling the bike forwards / back you should isolate the noise if it is. A little bit of chain lube on the nipple sorted it.
    Stevelol
    To check creaky spokes you can literally just sit on the wheel (without it in the bike) and roll it back and forward like you’re riding a space hopper (as we all do).
    fossy
    Check rear suspension bearings (if fitted) near the axel.
    JonEdwards
    For me it was the (bladed) spokes rubbing on each other – the wheel was still tight as a drum, just managed to get some dust in there and there was just enough flex when cranking hard in bottom gear to make it creak a bit. A flossing between the spoke sorted it.
