Home Forums Chat Forum While we are talking about fridges.
Viewing 10 posts - 1 through 10 (of 10 total)
  • While we are talking about fridges.
  • zippykona
    We have a small fridge at the shop with an ice box bit. The door has fallen off and we never use it. We could do with the extra space. Is there any way it can be removed and leave us with a functioning fridge?
    IMG_20240626_093506_861
    RustyNissanPrairie
    anything is removable when you have a Stihl saw.
    [/url]
    2
    johndoh
    I’d say not – refrigerant runs around the channels in the ice box.
    z1ppy
    Shirely the cooling element are part of the shelf and so wouldn’t be easily removed. I’d join your local “before the tip” group on facebook and look out for a more suitable fridge
    pocpoc
    EDIT: forget everything I said – I didn’t see that there were channels in the boxing bit that probably have coolant in.
    If the door is missing then surely it’s the same temp as the rest of the fridge? Can’t you just the use space to put fridge stuff in?
    leffeboy
    you might also find that that cooling element is actually what keeps the fridge cold.  There may not be another element elsewhere doing that job.  In our fridge/freezer with the freezer section up top the fridge was kept cold by a little flap with a controller that would allow the cold air down into the fridge section when needed.
    dyna-ti
    Holy crow. How old is that fridge ??. I’ve not seen that style of little ice box since the 70’s.
    Rubber_Buccaneer
    Sure you can but take a tip off old Bill Clinton and ‘don’t inhale’
    2
    the-muffin-man
    You sure the freezer bit is actually working!!
    My memory of them is there should be at least an inch of ice on it with a couple of fish fingers and an ice-pop half frozen in it! 🙂
    johndoh
    ^^^ LOL, true that.
