nickjb – Member
This is the sort of thing I was thinking:
That’s more or less what I was suggesting, just a DIY man in a shed with hand tools effort. You can do it yourself with a flat piece of stainless.
Start by scribing a circle the same as the PCD of your existing hub, and another for the new spoke holes. DIvide the circle up into 10º segments and punch mark where you want the holes. Then cut the steel. That’s the laborious bit – I’d probably use a cutting wheel to rough it out. Then a few hours with a smaller grinder and files and you have the shape right. No point drilling the holes before this in case you scrap the steel. Don’t forget to countersink the new spoke holes.
You’ll have to bed it into the existing hub because there’s probably an angle there. Epoxy and a suitable filler will do that job.
If an old disk was the right diameter, that may save some time, but more likely it will have pre-existing slots etc that interfere with your drillings.
