Home Forums Chat Forum What’s My Car.
Viewing 18 posts - 41 through 58 (of 58 total)
  • What’s My Car.
  • ElShalimo
    Upon reflection, I’ve changed my mind
    It looks like an early Triumph Thunderbastard
    benos
    It’s a tough one. And there’s no hint from those aftermarket Alleycat wheels.
    And I also thought it was pointing the other way at first!
    Cougar
    Not the earlier convertible though, a MK4 Estate with the mighty 1725cc engine.
    This is a 1725 also, if I’m correct.  The plate dates it as 1963.
    GlennQuagmire
    It’s a DMC DeLorean
    cynic-al
    I thought of a 304 convertible but the rear isn’t finned, and Peugeot is also in production.
    Also thought of Sunbeam Alpine but already been said.
    I did wonder about Amphicar
    johnners
    I don’t think you are. I believe the convertible was only produced 1962-3, the 1725 only appeared in 1965 in the mk 4. I think it would be a 1600, I’ll have to hit Wikipedia to check. Don’t have time to look now, it’ll suck me into a rabbit hole as usual and I’ve things to do!
    Cougar
    I have the benefit of knowing the registration number (unless my brain scrambled it in the five minutes it took to walk home, which isn’t wholly impossible).  1725 is what it comes back with on gov.uk’s lookup.
    MrOvershoot
    Like @scruffythefirst said my first thought was an early ish Lotus Europa possibly S2
    1280px-EuropaS2-sideview
    But I can’t quite match the sill line
    MrOvershoot
    1725cc In that case its not a Lotus & would make it a Roots group product or based on such?
    Cougar
    I had to google “root(e)s group” and yes, you would seemingly be correct.
    johnners
    It’s certainly possible, I think the 1725 was essentially just a bored out 1600 so probably a simple drop in swap. 1600 will be what it left the factory with but there’s a lot can change in 61 years!
    “root(e)s group”
    Rootes it is, Sunbeam was the sporty marque, Humber the posh one and Hillman was the boggo cooking variant.
    Cougar
    One of those is correct.
    piemonster
    Lotus Esprit S3 or Unimog. Can’t decide.
    Could quite easily be an Esprit S2, and what’s under the tarp is what hasn’t fallen off yet.
    johnners
    My money’s on it being a Hillman Super Minx then, I thought you’d said it was a Super Minx a while back? The other Rootes equivalents to the Super Minx are the Sunbeam Rapier and the Humber Sceptre and I’ve never seen either of them as convertibles in the wild, I’m not even sure they made them, as convertible was already a bit of a niche market.
    Edukator
    66 Sunbeam Alpine?
    allfankledup
    Tasvan — aka TVR Tasmin as per MrTricky
    andrewh
    A Super Minx I think. I’ll swing back over and ask them at some point, and report back. I could, of course, be wildly incorrect.
    So, was it?
    CountZero
    Like this one?
