What seatpost with ...
[Closed] What seatpost with infinite angle adjustability?
12 Users
I need a new seatpost for my beast... Because of the angle of the 'seat tube' it needs to be one that allows much more tilt than normal - something like a raceface XY0 for example (which unfortunately I can't find)
Any suggestions other than the really expensive posts? I don't really want anything expensive as TBH, my mantra is only for fun (I basically got it for free).
Needs to be 31.6 and 400+ length, no layback.
(the saddle in the pic works with the current post but has oddly angled rails which allow it to be set flat - other saddles end up pointing at the sky)
Posted : 04/09/2012 9:03 am
Have you tried an i-beam seatpost, they have quite alot of adjustment?
Posted : 04/09/2012 9:25 am
Hope Eternity has a huge range of adjustment - just not sure on the length thing .....
Posted : 04/09/2012 9:27 am
 nbt
you can get a 27.2 seatpost and a shim, don't forget
Posted : 04/09/2012 9:31 am
USE sumo or Hope post as said above.
Or another post with that type of clamp
Posted : 04/09/2012 9:34 am
Have a look at the Race Face Turbine seat post. Comes in a variety of diameters. The adjustment of angle is independent of the clamp by having a sliding collar and cam.
I have one on my Evil Sov. No problems so far,
Posted : 04/09/2012 9:36 am
Thomson Elite? Defo long and strong enough, not sure about the range of adjustment tho
Or have a look for a Salsa Shaft, that has a fairly unusual clamping set-up
nbt - I'd considered that but I prefer a bigger dia post given the angle and my size - I've bent a few posts in my time which in turn writes off the Sumo as I don't reckon they're all that strong...
Hope's an option but maybe rather expensive.
Clubber, I have an almost new 400mm x 31.6 Race Face XY, not XYO, so does have some layback but you can shuffle the seat forward and the differnce between an XYo and an XY is ~20mm ( I have both, just the XYO is 250mm long)
any use to you?
Posted : 04/09/2012 9:58 am
Hope eternity,use sumo or bontrager.
Posted : 04/09/2012 10:08 am
hope, close to infinite
Posted : 04/09/2012 10:10 am
amedias, drop me a mail.
I have found this too though
http://www.pedalon.co.uk/acatalog/bontrager-race-seatpost.html
mailed you
Posted : 04/09/2012 10:14 am
Clubber, how did you fit a rear disc to your Mantra? I have one of these gathering dust in my parents garage, you've just alerted me to the possibility of resurrecting it as a singlespeed!
Posted : 04/09/2012 10:30 am
KCNC SC Pro Lite has lots of adjustment. I think it's available in that size.
Posted : 04/09/2012 11:05 am
thorpy - mine came with a Hope C2 with the right adaptor but you can bodge one otherwise with an A2Z adaptor I believe. Like this:
http://www.amazon.com/A2Z-AD-PMR-Brake-Adaptor-Hayes/dp/B003QRB7F6
(You can get them in the UK, just the first link I found)
Posted : 04/09/2012 11:09 am
Thanks for that clubber, so yours has a hayes 22mm mount? Don't think mine has that (will have to check). Maybe its an older model.
Posted : 05/09/2012 2:40 pm
Yes, it has the 22mm mount.
Posted : 05/09/2012 2:52 pm
