What’s the best razor? Recently been using wilkinson sword Quattro cartridges….nice and smooth, but I struggle to get more than 2 or 3 shaves out of each cartridge before they are clogged up. Can’t see why more expensive titanium ones would be any better. Use.d to use cheap tesco cartridges but i got too many nicks, same with bic disposables.
So what’s best wet razor?
And while we are at it what’s your gel/foam/shaving stick of choice?
Merkur HD34C here. Switched to a real razor because the normal blades are so expensive! I use Feather Platinum blades, tried a few and these are amazing. I just use normal King of Shaves gel, foamed up and applied with a brush.
Merkur Progress and 11C razors for me along with an assortment of blades. Simpsons brush and Taylor of Old Bond St or Palmolive shaving creams. Floid, Speick or Proraso aftershave
I gave up on Gillette Mach whatever years ago due to high blade costs and nicks and rash. The foam/gel in a can didn’t help either I’d guess.
Merkur 20C using Astra platinum blades (or feathers if you don’t mind being slashed to ribbons). Proraso Eucalyptus & Menthol Shaving Cream. Real badger hair brush.
done all the DE razor thing but not for me, i finally settled on single edged injector razors. as usual, went in balls deep and ended up with about 8 different types, all good in their own way for different smoothness/aggressiveness. favourite currently is a PAL injectomatic with purple head, smooooooth as!
Gilette Mach 3 been using them years now. Nice custom handle from specialist shop. Nivea sensitive skin gel. If you razor is clogging after 3 shaves something is up with your technique – wash face with warm water so beard is soft, clean razor every few strokes with a swish in sink ? Mine go months although I admit I don’t have the thickest growth
Edwin Jagger handle, various blades (working through a selection pack) at home.
Shave oil under arko soap, lathered up on my face with a cheap Wilkinsons sword brush.
If I’m away from home, I use a disposable 3 blade Wilkinson sword razor and some shave oil, vaguely lather some soap on top just to make it easier to see where I’ve shaved.
Opposite end of the shave market for me. Cheap multipack of what ever disposable is available. Currently on gilete lady. Get about 3-4 weeks per razor and do legs with that too. I’ll use a shave foam if available, but a bit of normal soap does just fine too.
Gillette SuperSlim with Astra or Feather blades.
Don’t bother so much with soap & brushes; just Nivea shave gel now.
Number 3 around face – full 9 on neck area.
Smoothest cleanest shave.
I’ve finally found my perfect razor after 3 years and many many tests…it’s the Mongoose Stainless SE…it’s WAY better than the Cobra but rare as hens teeth to get.
It’s the only razor I can go ATG on first pass without any irritation. I can also go for multiple passes (5+) without irritation. Feather Pro blades will yield 7 BBS excellent shaves…I could double that number but for the sake of a few pence I just swap it out every week.
Tabac soap is my current favourite…it’s tallow based which might not suit all users.
Got a souped up version of a Merkur Progress but it takes too long to use.
Wilkinson Hydro 3 blades on a Hydro 5 handle as the 3 blades don’t clog as much as the 5 and the 5 handle has a ‘buzz’ mode which make cutting the awkward bits around the throat, etc, quicker.
Most cartridge razors have a ‘lubricating’ strip which just serves to make them drag and seem to need changing more often. Mach 3 is one such.
The hyro doesn’t have such a strip and I use it with KOS shaving serum (the green one) and the blades last quite a while. Had 4 weeks of acceptable shaving the other month.
I shave once a week so use Gillette disposables to hack the fuzz off (I have “weird beard growth” according to a barber) followed by a Gillette Fusion (I think). Proper soap and brush. Tried lotions and potions and this is good for me. If I had to shave every day I’d grow a beard.
Got a Merkur razor of some description – 33C, perhaps?
I initially used Astra blades, but then bought a selection pack I’m currently working my way through, trying a different one at each new blade until I’ve worked my way through them.
Only shave once or twice a week, so my current stash of blades is probably good for about 4 years and only cost £11….although I probably won’t bother using a couple of them out of the selection pack as initial impressions weren’t great.
Have been using Taylors shaving cream stuff, but got a Muehle wooden bowl & soap for my birthday last week, which is good but quite different. Cheap Body Shop brush seems to do the trick.
I’ve been using a Merkur 38C and a variety of blades over the last 5 years, currently on Gillette blades (they don’t last long at all though – 4 shaves) from Boots as I was in a rush. Astra’s and Derby’s are better.
King of shaves gel, though I also have a Badger brush and Maccaroot shaving cream if I’ve got time.
as a slight aside – I am looking for the smallest lightest bikepackable (staying in B&B’s) shaving foam I can get for a trip in a few days – any recommendations ? Will be leaving the Gillette fusion at home and taking one of wife’s disposable Asda ones.
Used to use Gillette excel but moved to Gillette mach 3 a good few years ago, not felt the need for anything more. Quick and smooth, usually shave every other day, unless I have to go into the office and see people IRL.
I have to shave every day for work (Army) and have done for the past 21 years. I’ve tried everything and am now using Wilkinson Sword Hydro 5 and find them spot on. I’m easily getting a month out of a razor. As for shaving gel, I use either Nivea sensitive gel or Bodyshop Maca root shave cream with a brush. This is pretty good stuff.
I’ve tried using a ‘proper’ razor but they shred my face.
Your razors shouldn’t be getting clogged up after a couple of shaves.
You would be better off with a small bottle of shaving oil.
I’m using a gilette fusion proshield at the moment, gives a very smooth shave, combine with nivea shaving gel.
Merkur 25C with Feather blades. Bluebeards pre shave oil, Trumpers sandalwood soap, Vulfix silver tip brush.
Used multi blades and shave oil for years, but that was because I travelled a lot with work and needed to shave every day and it packed up small. I wouldn’t go back to multi blades now.
have used pretty much most brands in my time in search of the perfect blade…ended up settling on the gillette fusions
i also use a phillishave
but i now have a beard so i only use the phillishave to get rid of the tache and tidy up the edges of the beard then i use the blades to get a smooth finish
