As per title really. I think hope recommend silicone based??
Old tech m4 brakes
Brake fluid 🙂
Castrol red rubber grease
Hope use Hunters silicon plumbing lube. I have a small bottle and it works well. If it's good enough for Hope, it's good enough for me. After all, who should know their brakes better than them?
Silicone lube
Same stuff hope use but in a bigger bottle than a bike shop will sell you.
You can use it on suspension seals too.
Polypipe SG100 Silicon Lube grease from Screwfix.
I use the Car Lube multi purpose silicone grease on Hope E4
I've used silicone spray without issue for years, it's cured a squeaky seal on the master cylinder too.
Anyone else initially read that as "what prison lube?"
Anyone else initially read that as “what prison lube?”
Err...just you...honest 🙂
Excellent. Thank you all. Will try that hunters
castrol red rubber is a little too sticky for mtb calipers.
use silicone spray (in a cap applied with cotton bud) or brake fluid
That Hunters stuff has worked perfectly. Thank you!
