What piston lube?
[Closed] What piston lube?
 P20
[#10813735]
As per title really. I think hope recommend silicone based??
Old tech m4 brakes
Posted : 15/09/2019 5:51 pm
Brake fluid 🙂
Posted : 15/09/2019 6:03 pm
Castrol red rubber grease
Posted : 15/09/2019 6:07 pm
Hope use Hunters silicon plumbing lube. I have a small bottle and it works well. If it's good enough for Hope, it's good enough for me. After all, who should know their brakes better than them?
Posted : 15/09/2019 7:04 pm
Silicone lube
Same stuff hope use but in a bigger bottle than a bike shop will sell you.
You can use it on suspension seals too.
Posted : 15/09/2019 7:09 pm
Polypipe SG100 Silicon Lube grease from Screwfix.
Posted : 15/09/2019 8:48 pm
I use the Car Lube multi purpose silicone grease on Hope E4
Posted : 15/09/2019 10:17 pm
I've used silicone spray without issue for years, it's cured a squeaky seal on the master cylinder too.
Posted : 16/09/2019 3:13 am
Anyone else initially read that as "what prison lube?"
Posted : 16/09/2019 4:19 am
Posted : 16/09/2019 8:54 am
Anyone else initially read that as “what prison lube?”
Err...just you...honest 🙂
Posted : 16/09/2019 9:41 am
 P20
Excellent. Thank you all. Will try that hunters
Posted : 16/09/2019 10:10 am
castrol red rubber is a little too sticky for mtb calipers.
use silicone spray (in a cap applied with cotton bud) or brake fluid
Posted : 16/09/2019 11:27 am
 P20
That Hunters stuff has worked perfectly. Thank you!
Posted : 20/09/2019 5:46 pm
