Seems passthru is something found more on larger units .
The inui 20000mah has all the features I want. -charge and discharge at the same time. But if it was half the size it would be much better as the 20k unit is quite bulky.
Nitecore do a waterproof 5000mah one. With pass through and so do cinq but again 10k just seems a more useful size these days.
Context – I want to have a battery pack on charge all the time to use as a buffer pack – I have had bad experience with overvolting when running down hills at high speed and no load on USB converters. -killed igaro d3 in Canada this way and the two cycle2charge units died just riding too and from work without load.
