Having never had or used one before I’ll be using a wood burner and gas central heating to stay warm this winter.
The wood burner is a 5kw MrFires Firecracker in large, so accepts logs up to 300mm long and briquettes and was installed in February this year with a lined flue.
I’d like to think I’ll use it in the evening when home from work for a few hours and at the weekends for longer. It’s in a tiny, period, cottage so will hopefully heat the whole place through.
It seems the type of wood I burn is reminiscent of asking for what tyres to use on here!!!
Via Google I’ve settled on birch for easy burning,it’s of heat & flames and found this supplier online:
https://www.uklogsdirect.co.uk/kiln-dried-logs-c1/kiln-dried-birch-logs-c4/kiln-dried-birch-logs-half-crate-p3
Anything else I need to consider, any recommendations of online timber suppliers, advice???
Ta
