I’d use mobile xhp222 but then I have a tube in the garage.
Same, as I already have some in the garage…it’s probably total overkill for this application, but it should last ‘forever’ and it’s hardly any more expensive than a tub/tube of ‘mystery grease’.
Superb resistance to water washout and spray-off Helps assure proper lubrication and protection even in the most severe water exposure
conditions
Highly adhesive and cohesive structure Excellent grease tenacity, helps reduce leakage and extend re-lubrication intervals for reduced
maintenance requirements
Excellent rust and corrosion resistance Protection of lubricated parts even in hostile aqueous environments
Very good resistance to thermal, oxidative and
structural degradation at high temperature
Helps extend grease life and enhance bearing protection in high temperature applications
helping to reduce maintenance and replacement costs
Very good anti-wear and EP performance Reliable protection of lubricated equipment, even under conditions of high sliding with
potential for extended equipment life and reduced unanticipated downtime
Broad multi-purpose application Provides potential for inventory rationalization and reduced inventory costs
