Blimey where did you find all that mud? It’s dusty-dry here in Malverns/FoD and we only found a couple of patches on that black mountains route. And that’s normally at least a bit underwater!
The easiest way to describe the path is to the trig point after climbing up Y Das to the fence line. Then immediate right onto a reasonably well defined path of rutted peat that slowly descends for a couple of km. It quite hard work tho. Then up the next rise, drop right off the top of there down a very fast grassy path which if you keep heading left towards the trees will end up at a gate. Over that, proper streambed/rocky gulley through the trees out onto fire-road, one turn on there and into 45 seconds of even rockier singletrack that is a starve segment. Ends up at the CP at the bottom of GF descent. A lot shorter but loads of fun.
Warning tho – only if it’s bone dry. That peat-y path is a bog even when the rest of the route is dry. It’ll suck the joy out of you – ask me how I know 😉
GPX if you want it – email in profile.
That toast pic has made me hungry 🙂
