Using a washer to c...
[Closed] Using a washer to create space for rotor - Acceptable?
5 Users
Hi,
Just wanted some views on what I have done to make some clearance between my rotor mount and caliper mount. As you can see I have added a pedal washer and it fits perfect as a spacer. Is this acceptable in terms of safety.
[url= http://thumbnails106.imagebam.com/22225/aa079e222247013.jp g" target="_blank">http://thumbnails106.imagebam.com/22225/aa079e222247013.jp g"/> [/img][/url] [url= http://thumbnails105.imagebam.com/22225/7f26a1222247082.jp g" target="_blank">http://thumbnails105.imagebam.com/22225/7f26a1222247082.jp g"/> [/img][/url]
Thanks,
tBike
Posted : 25/11/2012 4:38 pm
 br
You'd be better spacing out either the mount of the rotor as by putting it on the axle you are deforming (only slightly I realise) the fork.
Or is it rotor to fork clearance that's the issue?
Posted : 25/11/2012 4:42 pm
iv been doing that for about 3 years with my fox 36, the hope rotors need more room to clear the fork.i source a copper spacer off ebay exact fit for the bolt through axel jobs a good one .
Posted : 25/11/2012 7:37 pm
Like B R says,you are now running a disc mount on the fork that isn't parallel to the disc. The caliper might adjust unevenly to suit.. but it's not the best option. You also now have a washer on the inside of the dropout instead of the serrated face of the hub.
Posted : 25/11/2012 8:29 pm
I've used a couple of washers behind a caliper mount before, no harm in that. As said above I'd have reservations about spacing the fork leg.
Posted : 25/11/2012 9:40 pm
