From many years expereince of electric planes, dont put it down till it stops , especially on a hardwood floor, or a carpet, it will take chunks out.
dont poke your fingers in the dust outlet slot when its running,to clear a blockage, Kevin you do remember that instruction,
Never plane near the cable always keep the cable clear of the panner,
always make sure some daft muppet doesnt walk i with a tray of tea and biscuits, falls over cable launces tea and biscuits at you, while the plane still running is launched accross the room out of your hands,
Only plane half way accross edge of door, tuirn door over and re plane other way to stop door edge spelching out.
and if the door is clamped betweeen your knees and the door suddenly moves backwards, the plane will cut into your knee, it hurts and bleeds a lot, and requires a few hours in hospital, along with a customer teling to please bleed outside , i dont want blood on the carpet.Done that.
Never leave the planer unattended as some teenage muppet with the brain cell of an amobea will pick it up and pull the trigger while looking at the blade and just be about to feed his fingers into it.
