Transition Spur alt...
Transition Spur alternative
17 Users
Would really like a Spur in X01 spec but nothing available. From what I've been told, there are none coming into the UK next year either.
What else is similar?
11kg or less.
120mm travel.
Size small.
Full sus.
No parts like a lefty fork or brain shock that need to be sent off to specific places.
In stock. Or available in spring.
Posted : 10/12/2022 7:29 pm
I think anything high end like X01 is likely to be AXS going forward, why not just take a Spur GX or frame and upgrade/custom build? There is good GX stock arriving in the new year
Posted : 10/12/2022 7:37 pm
YT Izzo, know nothing about it other than it looks similar. Take a look at the Pinkbike downcountry bike field test, all 120mm ish bikes on there
Posted : 10/12/2022 7:38 pm
YT have just announced a bunch of price cuts, there's 5-600 Euro off some Izzo models. Pretty direct Spur alternative
Posted : 10/12/2022 7:51 pm
I do like the YT Izzo, but the yellow is a bit bright.
The GX spec Spur has lower spec forks and shock too. If it was just the gears I'd be tempted to go for it and upgrade/sell the GX stuff new.
Posted : 10/12/2022 8:19 pm
Izzo comes in black too, and I think green
Posted : 10/12/2022 8:31 pm
IZZO uncaged is yellow only. I wish it was black. I'd order one this weekend if it was.
Posted : 10/12/2022 8:49 pm
The Core 4 is black and has a factory 34 and X01, and you have 1500 Euro left to upgrade
https://www.yt-industries.com/products/bikes/izzo/uncaged-7/466/izzo-uncaged-7/
https://www.yt-industries.com/products/bikes/izzo/core-4/431/izzo-core-4/
Posted : 10/12/2022 8:57 pm
All a bit academic as there don't seem to be any Izzos in small as per the OPs request
Posted : 10/12/2022 9:11 pm
I was looking at the transition spur for an xc bike in the summer but instead built up a stumpjumper s works frame with xt, 34 grip2, 240/stans crest wheelset and it came in at the same price as a spur and actually weighs 12kg in the real world (S5/XL). I preferred the quality of the frame, internal storage and being able to spec better parts than a complete spur.
Posted : 10/12/2022 9:12 pm
I was in the same boat December last year. No X01 Spurs in stock with my local Transition dealer and they said none coming until 2023 at the earliest. They had one large GX Spur so I took that. Best descision I ever made.
The differences are negligable. The only difference between the Sidluxe Ultimate and Sidluxe Select+ rear shock is that the air can on the Ultimate has a tiny bit more CNC machining which loses an extra ten grammes of weight.
The SID Select+ I'd argue is actually better than the SID Ultimate for trail use because you get the full size damper rather than the strpped back Race Day one. I'd rather take the 150 gramme hit and have a fork that is actually more plush than the Ultimate. Also, the SID Select+ has a proper adjuster for the rebound and not that tiny allen key thing.
I used the £1,000 I saved going with the GX model to buy some nice carbon wheels. I'll upgrade the GX stuff to X01 as and when things wear out but I'm 1,400 miles into the stock chain and stil haven't hit 0.5% wear according to my Unior chain checker.
Posted : 10/12/2022 9:14 pm
Interesting about the SIDs and performance.
That Rocky Mountail Element is too heavy at that spec. Does look nice though.
I'll have a look at a stumpjumper but think it might be too 'burly' for me at 58kg.
Posted : 10/12/2022 11:21 pm
Obviously recommend what you have
Elite in small is showing in stock.
https://eu.intensecycles.com/collections/bikes-in-stock/products/sniper-t-elite-1
Posted : 11/12/2022 1:37 am
Specialized Epic Evo? I don't think any of the Evo models have Brain shocks.
Posted : 11/12/2022 7:30 am
I was waiting on a Spur frame for 18mths. Gave up in the end and purchased a full build Epic Evo comp. Swapped everything with the build kit I had for the Spur. Absolutely outstanding bike around 22lbs and more than capable. No regrets at all and glad I couldn't get the Spur as the Epic (imo) is more of an all-rounder.
Posted : 11/12/2022 8:46 am
Posted : 11/12/2022 8:49 am
Santa Cruz Tallboy?
Posted : 11/12/2022 12:28 pm
I just got a Scott Spark. There are some big discounts on them at the moment and it rides very nicely. You can change the head angle by rotating the cups in the frame and it's very capable - trail capable rather than XC race capable.
Posted : 11/12/2022 2:02 pm
I’d just go for a GX Spur. As Devash said, the Sid Select+ fork is arguably better and certainly not worse. I swapped the damper to the lighter Race Day one from the Ultimate and is negligible between them. The only different in the two shocks is a bit of machining on the eyelet that saves you a whole 3g. Yes. 3 whole grams. Otherwise, totally the same.
I adore mine, it’s ruddy awesome!
Posted : 11/12/2022 2:31 pm
Santa Cruz Tallboy?
It's a bit heavy for me. I looked at the Blur TR but find the sizing odd with quite a long seat tube in a size small with a short reach. Medium has too long a seat tube for me.
What size did you get? And how tall are you? It was at the top of my list but it seems quite short.
Posted : 11/12/2022 2:37 pm
I'm 5'10" and on a Large. I think the reach is 470, which is the longest of all my bikes.
I've only had it a week but have given it a baptism of fire - it's handled Megadeath in Calderdale, the Beast in the Peak and Fryupdale in the North Yorkshire Moors very well. I've bought it to be a race bike that can handle day to day XC riding but it turns out it's more aggressive that that.
Posted : 11/12/2022 3:17 pm
One thing to note is that UK / EU Transition pricing has gone up massively recently so the GX Spur is now £6k which is an absolute pisstake.
Even though I absolutely love the bike I'd definitely be looking at the Epic Evo as an alternative right now. Slightly better frame build, same good warranty. Probably better support because of the larger dealership network and easily available spare parts.
Posted : 11/12/2022 3:53 pm
Epic Evo is odd sizing like the Blur TR. Long seat tube and short reach in a size small. Medium has too long a seat tube.
Posted : 11/12/2022 4:28 pm
Rocky Mountain have a crazy discount on an element C30 atm 😉
PRE ORDER Element Carbon 30 2022
is that some sort of dodgy website? or has this been discussed and i missed the memo?
Posted : 12/12/2022 8:43 am
^^ i belive i found it from rocky mountain's mailing list
I assume since its a 2022 model its a complete clearout, theres loads of other models but all mostly sold out
I was tempted. Bt it really shouldnt
Posted : 12/12/2022 9:38 am
Really liking my Stumpjumper, pedals well, can ride proper trails on it. Its a bit more than your weight target.
Posted : 12/12/2022 10:38 am
