Yeah, ideally when using a tracksaw, rather than using just trestles alone, it’s best to have a sacrificial board (another 8×4) underneath so that you get full support.
A lot of people actually use a sheet of insulation board for this as it allows good support and you can cut just through your material without wearing the blade in other wood -based materials.
Having a few long lengths of 2×3 or whatever running the length, bridging the cut is also a good way.
Always think about what is going to happen as soon as the material is cut through.
Is the offcut supported.
If you’ve got the floorspace, it’s often better just to lay down some sacrificial strips directly on the floor and do your cutting there. Same rules apply though.
