Have you tried slamming you saddle all the way forward on it’s rails to simulate a steeper seat angle?
No, because prior to jameso’s tip that would only get me to 78.
Put a bit more air in your shock until you’ve steepened the angle at sag.
Interesting, if this gets close enough then would save me getting the dropper out to fit my offset post.
But bear in mind that most super steep seat angles aren’t what they claim. I’d overlooked the Pipedream Moxie because the super steep seat angle (77.5 static so even higher at sag) was too much for me. But I found out that at my (fairly high) saddle height it’s over two degrees slacker than that – which works perfectly.
Yep, planning to do some calculations using actual seat tube angle.
