I thought the point was only to add oil soaked felt rings at the seal to overcome stiction.
If there’s enough oil sloshing about in the RH leg to get sucked past the seal on the damper (basically sealed gas strut), is there just too much (and too low a viscosity?) oil being poured in?
Surely you can still use the oil soaked felt rings and maybe add a smidge of oil to the LH (air spring) leg just to minimise stiction? and smear grease on the RH bushes/damper shaft to avoid the damper ingesting extra oil…
I suppose the other obvious question is, can the fixed damper be replaced with something else?
Other than that gas strut the fork is of pretty similar construction to lots of others like Rebas etc (air spring in LH leg, Damper in RH leg), so could an old Marzocchi style “open bath” hollow pumping rod with a hole at the base be installed in the LH leg? or could a fully serviceable aftermarket “Damping Cartridge” be assembled?
Or is that a bit much effort for what is essentially a bargain bin fork?
