Home Forums Bike Forum Steel bikes going against the curve
Viewing 40 posts - 41 through 80 (of 186 total)
  • Steel bikes going against the curve
  • philjunior
    I think for it’s rigidity, alu has failings in the sense that I’ve cracked 2 (maybe 3?) alu frames.
    If we’re playing that game, I’ve cracked 4 steel frames (after a reasonable amount of use it should be said), 1 alu frame (after a reasonable amount of use, in a location where, apparently, all of that design used to fail), and 1 ti frame (in a very short timeframe).
    I’ve got an aluminium frame that’s had more use than 3 of the steel frames ever had (one was second hand so I don’t really know how much use it had prior to me owning it) and is still going strong – like the ride, the durability of a frame comes from good design (and manufacture), I suspect that because steel has a reputation for being fatigue resistant, until the new EN tests came in many steel frames weren’t designed with much thought given to it.
    corroded
    My carbon Grade sometimes feel like it has a sprung rear end. It’s more comfortable than my steel Stoater.
    kayla1
    Gaaaaaaaaaaaaaaaaaaaaaaaaaaaagh! Stop posting Cotics! You’ve pushed me over the edge. There’s a Flare on its way… 😯 Holy shit that’s a lot of money 😯
    nedrapier
    Bikes are good.
    1880’s tech though.
    kayak23
    Gaaaaaaaaaaaaaaaaaaaaaaaaaaaagh! Stop posting Cotics! You’ve pushed me over the edge. There’s a Flare on its way… Holy shit that’s a lot of money
    Worth it for such a beauty. Well done! 😀
    chakaping
    Bit cheaper than a Starling now though, so just think about what you’ve saved.
    Alex
    Stop posting Cotics! You’ve pushed me over the edge. There’s a Flare on its way..
    Finally 🙂
    Bregante
    I’m a total steel convert. Like others, I’ve owned carbon and aluminum bikes aplenty but both my road bike and my mountain bike are steel because I love the way they ride.
    It’s incidental that they look OK too (IMO)
    paton
    Carbon fibre is still evolving
    bigad40
    I looooooove my Reynolds 853 steel tube Stanton Slackline.
    Sorted geometry means it goes round corners like nothing else, confident on everything.
    Small thing like when small stones flick up on the down tube it sings with a sweet ‘piiiing’.
    PeterPoddy
    I do love a nice steel frame. I care not how stiff/compliant/heavy/light/niche it is, it just seems to feel nice to ride. A good steel frame has a lovely zing to it, a ‘live’ feeling that no other material can really replicate IMO.
    It’s nice to see some of the big manufacturers catching on to, IMO.
    Tom_W1987
    Been saying this for years, they tried maximum stiffness in motorbikes a few years ago and they turned out to be chattery unridable pieces of crap,
    They also gave up on steel trellis frames, in the best engineering terms – donkeys years ago and have even been slowly moving away from aluminium twinspar designs to carbon – Stoner still thinks the carbon Ducati machine was the best bike on the motogp grid in 09 until Rossi came along and ballsed up the development.
    cookeaa
    I would say I’ve become “Frame material agnostic” over the years, pretty much all of the choices out there have some benefits and some compromises thus was it ever…
    But bicyclists seem to become oddly tribal about what is basically just an item of sporting/leisure equipment…
    Do Badmintonists start reaching for armchair physics and whimsical descriptions of intangible “Qualities” when discussing Rackets?
    Budget Vs Desired Functions innit, let’s not kid ourselves…
    Steel isn’t anymore or less “Real” than the rest, it’s just another (well marketed and catered for) Niche in a market full of Niches….
    wobbliscott
    Carbon Fibre is still evolving. So are Steel alloys. So are Aluminium alloys. There is no such thing as ‘the best’ or ‘the ideal’ material for a bike frame. Each material has various pro’s and cons. You have to decide what the best blend of pro’s and cons are for you.
    Ultimately it’s not about the material – it’s about the design and the talent of the design engineer to exploit the properties of the material to their best. Same rules apply: strength, weight, price. Choose any two whether it be CF, Aluminium alloy or Steel alloy.
    Cy is doing a great job I think (and i’m sure other small independent manufacturers of metal bikes), he is building bikes that are every bit as good as CF bikes at double the price – he’s punching way above his weight when you consider the resources of the big bike companies building the super expensive carbon bikes. If he had more resources for R&D could take steel frames alot further if he were not limited to simply welding tubes together and had access to far more sophisticated, and expensive, manufacturing methods to create more efficient designs. But clearly there is a very limited market for that so not cost effective for him to pursue. 3D printing might just change that balance of economics in the not too distant future.
    andytheadequate
    I’m glad that the people on page 2 realised the main benefit of steel, the bikes just look so damn sexy.
    I have a aluminium Canyon Spectral (also sexy, in a completely different way), but if I ever replaced it I think I’d have to go for a Cotic rocket/ flare.
    epicyclo
    The nice thing about steel being all 1890s is that an 1890s bike still rides as sweetly as it did new.
    They had steel bikes in the 20-25lb range back then, and if we named them after the surfaces they rode and raced them on we would call them ‘gravel bikes’. 🙂
    aracer
    Fundamentally the way a bike handles is so much more about the design than the material it’s made from – and the biggest pro/con of the different materials is “how it looks” – if you’re not racing the real difference in performance is tiny (certainly on something with 2″+ of low pressure rubber any difference in comfort is mostly in the marketing man’s mind).
    wicki
    You stick a dirty great 3 inch tyre with low inflation on a bike that compresses maybe an inch and then sing the praise of a couple of mm flex in a tube set 🙄
    jameso
    Vertical flex is minimal in a bike frame yes, lateral twist and spring under cornering and while riding generally can be very different between a slim steel frame and an oversized aluminium equivalent. That’s the flex/spring ride feel that people describe. The ‘comfy rear end’ bit is mostly imagination though as you say – seat post flex and front triangle give, probably / mainly.
    epicyclo
    jameso – Member
    …The ‘comfy rear end’ bit is mostly imagination though as you say – seat post flex and front triangle give, probably / mainly.
    I’d add saddle rails to that too. Noticeable when moving from a railed saddle to a beam one like SDG.
    buckster
    The 2.3″ of rubber argument is almost valid. As each bike has 2.x” of rubber, then the frame material kicks in when defining the ride, has to. They do not feel the same to ride, they being carbon, steel, alu etc.
    Also, being pedantic, a steel racing bike with an identical geometry to a carbon bike will be just as good, carbon racing frames and lightweight, now that is marketing.
    jameso
    @epicylco Yes. Ti vs steel rails is something I’ve noticed adding a bit of comfort on the road bike. Same OD but 1/2 as stiff.
    It will do to a point, the tyre only compresses so far, takes force to do that and by that point it’s applying associated load to the frame.
    I’d tend to agree on lightweight bike marketing, 15lb road bikes can feel great to ride but cyclists who don’t race much have always placed (imo) too much importance on a fairly small amount of weight variation. If low weight wasn’t as high up the priority list we’d see a lot more steel bikes out there.
    mindmap3
    Rubbish the CEN tests have resulted in stiffer steel frames than the past, so you can’t be telling me they are all flexy. I don’t get the steel love thing, and that’s from someone who rode steel frames for years. Quite frankly CF is the best material for bikes and aluminium is a brilliant cost effective solution. Steel well that is 1900’s tech and only really useful for custom builders.
    I spent some time on the new Stanton Slackline and I think that 853 tubeset is bloody brilliant – it was so much more compliant than my steel Switchback and if I’m honest more compliant than my Mk II Ti frame which is pretty stiff.
    I never had an issue with ali HT frames, but looking back at my Chameleons, Sub-Zero and Tazer I’m not sure I’d go back to ali for a HT (the later two both cracked).
    Skankin_giant
    After around 17 years of steel, (Orange Clockwork, 3 x P7, Kona Explosif, Haro Mary, Singular Swift x 2, Kaffenback) I’ve bought an Aluminium framed bike (Cannondale Beast of the East 1)….. I was put off for many years after having a Cannondale road bike in 2005 and shaking my teeth out on the roads of Shropshire & Wiltshire…. when I tested the bike I was pleasantly surprised by how frame design has come on but that might be down the the plus tyres.
    I’ve still got 2 steel frame bikes as I don’t think I would want to be without one as I enjoy the ride.
    Cheers, Steve
    dragon
    epicyclo +1 to both your points.
    One thing that doesn’t tend to get mentioned is speed, as you get faster the bike tends to ‘float’ over the surface more. My CF road bike if ridden slowly is harsh, but get it up to speed and it is amazing and I could ride it all day.
    Seat post flex is interesting, it does make a big difference, but IME it isn’t always a positive (particualrly on road bikes). I had one of those super compact Giant OCRs and the seatpost could move big amounts, but it actually seemed to result in me getting tired earlier, because my legs and core were having to damp a large movement and couldn’t just focus on pedalling.
    buckster
    Absolutely, there is a perception that low weight = performance/quality. The perception exists in many other things too, watches for example. There was a fascinating article in Cyclist a few years back where they worked out the maths for a (from memory) 1kg difference in frame weight, and the resulting power gains. On a climb it was about 8 watts from memory, on the flat it was negligible to zero.
    When I was racing, the then material of choice was Scandium, I ordered a Scandium frame expecting life changing speed. Whilst waiting for the frame, the season started and the only bike I had was an old steel Pinarello, I raced this and my results were the same as my ‘old’ 7005 bike. When the Scandium frame arrived, results were identical. Its in the mind or the marketing. Ive had the same road bike since 2002 now (Spesh S-Works), nobody could convince me I would go better on a modern carbon frame.
    If you are a subscriber, you can read it here: http://cyclistmag.co.uk/free-articles/2/?content=why-saving-weight-is-a-waste-of-money&channel=null
    andybrad
    im struggling to buy into the frame flex after having a stiff (ish) bike. whats the point of having a flexy bike (although on a road bike i totally get it) on a full bouncer and then having something like carbon wheels or similar?
    jameso
    My bodyweight probably changes by that much over a few days, a water bottle is 3/4kg and I don’t notice a change in pace as it empties. So it may be mostly in the mind, that’s an important part of how a bike works for us though, about mindset and matching the bike to that perhaps.
    Personally I like steel for frames and forks because it’s durable, safe and it looks nice, on top of that the ride feel can be as good as I’d ever expect. Old technology is good, it’s very well understood and easily replicated. When I think of what makes a really great bike it rarely if ever includes a lot of ‘F1’ type technology or material needs, the best bikes imo tend to be the simpler ones with great geometry that carry on working. So back on topic, that’s what I like about a bike like the Rocket or Starling, or a steel diamond frame – I’d have a belief that it could/would last me longer. If I like the ride it’s seen as a keeper and that durability is a big part of what gives something quality or value, to me. If you rate ‘ultimate performance’ most highly and/or see things as short-term ownership along the path of keeping up with performance aspirations, newness etc you might disagree.
    None really, but stiffness and flex are the same in that too much of either makes a bad bike. Some riders argue that flex in a frame when pedalling is a good thing and this ‘stiffer BB’ thing of carbon race bikes is only an advantage in the way light wheels are, mainly in instant responses to effort ie reacting in a bunch or to sprints, rather than any advantage over a longer ride. I’d agree with some of that. Sus bikes do need stiffness to keep linkages working but I’m not sure a totally stiff susser is ideal, as mentioned before re motorbike design.
    philxx1975
    It’s all marketing , proper bike companies are not interested in forum warriors so this segment of opinion is moot. Little companies have a vested interest in niche Sales and keeping you happy look, at planet x there will be lots of companies happy to see them on their arse as people buy on price far more than the percentage who buy with their heart.
    mboy
    o I’m afraid it is correct to say steel tech in bike industry hasn’t moved on a lot since the 1930’s.
    I think Reynolds, Columbus, Dedacciai etc. Would all like to disagree with you. Not only have we seen stainless tubesets arrive (including the very recent addition of Reynolds 921), we’ve seen various types of butting including most recently the DZB tubes that do away with the need for gussets, externally butted tubes, different stay shapes, and the removal from sale of older and less relevant tubesets.
    That’s the thing… You don’t want flex everywhere. By the same token you don’t want it nowhere. A bicycle is a selection of parts all brought together to create something that is hopefully greater than the sum of those parts. If you design an incredibly stiff frame and then hang the world’s stiffest parts off it, then it’s going to be a boneshaker. If you take a super flexy frame then cover it in lightweight flexy components, you’ll spend most of your ride wondering just when the back wheel is going to overtake the front!
    My personal preferences mean I like quite different things for different applications. A full suspension frame inherently has a lot more flex in it than a hardtail, so I like to mitigate that somewhat with stiff(er) wheels (but not too stiff, I tried ENVE’s and didn’t get on with them for instance) than I’d run on a HT. The same stiff wheels on a HT would provide a very jarring ride unless a particularly flexy frame was used, which may provide too many compromises elsewhere, so I prefer the slightly flexier wheels with a moderately stiff (but not too stiff) frame on a HT to give some flex/feel/compliance to the ride. I can say this with fair confidence having ridden bikes for 25 or so years off-road, that I’ve come to know to a certain degree how to achieve what I want. Of course it’s the frame designers who understand it far better than we do who will know exactly how to get what they want from a frame, we just have to hope that some of them have goals that marry with ours when selecting one.
    Carbon needn’t be all that stiff either. If you know what you’re doing then you can make carbon handle exactly the way you want to, but from experience riding and selling the things, I’d suggest less bicycle manufacturers know how to design well with carbon than they think they actually do. Though the same could be said for Ally, Steel and Ti too…
    Oh and in terms of small volume manufacture, which lets face it, is where a lot of us are turning our attention these days, steel tubing is still peerless as a material to work with. The ability to quickly make a one off (either as prototype or for unique customer order) from a set of pre purchased tubes that you’ve selected and modified, in a short space of time, to provide a frame that’s only real downside is a slight weight disadvantage against its peers (in most cases, like for like, we’re talking 1lb here, maybe a touch more, not huge gains), is fantastic! I recently came to the conclusion that my ideal HT frame doesn’t exist, so I’ve sat down and drawn the geometry on BikeCAD and have talked to a couple of builders about creating it for me. Within the next 6 weeks I could conceivably be riding around on something I’ve designed made out of finest steel! The fact that when pushed, I tend to prefer the inherent ride qualities of good quality steel tubing in a HT frame over other materials has also had something to do with my decision of course, but that’s just another advert for the wonder material!
    Tom_W1987
    Weight is important to an extent, losing 300 to 400g in the frame allows you to add weight elsewhere without the bike hitting over 33lb. Example, larger brake calipers, a stiffer fork or coil suspension.
    I’d rather have a coil suspended carbon bike than an air suspended steel bike….by far….why would you want to gain vertical compliance with undamped frame compliance instead of more sensitive or controlled suspension?
    jameso
    It’s the lateral flex of the front triangle, outside of the suspension linkages moving in line with the wheel, that could be the benefit (edit – or preference, more than ‘benefit’). Like you said about motorbikes earlier, same thing to some extent I expect. There’s very little vertical movement in most frames, a few mm of av steel tube deflection over a very high load and less under average riding loading. That can add up, compared to sus movement it’s still tiny.
    andybrad
    I understand that you can make different materials act in different ways.
    But how come an “old tech” steel frame bike with similar spec costs the same as an off the shelf carbon one. (lets compare a rocket and spectral?)
    I understand that custom builders work with steel. This is because its easier to work with and they will get better results. Im sure that if they could work with alu or carbon in the same cost / ease they would do.
    buckster
    To follow your logic, wouldn’t all frames be built of the same material? I also genuinely believe that the frame builders are passionate about the ride steel provides, I dont believe many would drop steel if they could – or havent done so already
    jameso
    Volumes, route to market. Marketing – on either side / you decide.
    Custom builders could work in Al also but it’s not in demand in the same way. A market demand thing, that durability and ‘quality’ that I mentioned perhaps. Some work very well in carbon – Richard Craddock / Filament, Calfee; seems a much smaller market though.
    And not belittling their skill here at all, but I could lay up a basic carbon frame if I had the ‘kit’ in front of me. Most of us could. First one might be a bit frilly, second or third should be passable. I can’t TIG weld a thin-wall steel frame though and it would take me a long time to learn, if I ever could I’m not sure. It can take a lot of people / a number of processes to lay up a decent carbon bike. A lot of tooling and CAD time in advance. Yet steel isn’t light on time and tooling needs either and maintaining alignment isn’t easy.
    There’s plenty of people with much more direct experience of this comparison than I have – Cotic, Swarf for starters, MickMcD here, but from what I do know of the production side I don’t think it’s fair to see steel as old thf simple tech that should be cheap and all carbon as new ‘F1’ thf high tech + expensive.
    deviant
    The lateral flex re. multi pivot linkages and steel frames like the Starling are good and mirror my own experiences. As someone else said, the rear seems to ‘wriggle’ and find a smoother route through harsh terrain than a stiffer made rear end, I like this effect, others may not.
    What I find amusing is some posters coming out as anti steel and pro stiffness at all costs allowing the suspension to do it’s thing….but then moving over to plus size tyres and silly low psi measurements which is in effect the same thing they’re criticizing steel frames for….undamped flex/bounce!
    None so strange as MTBers hopping on the next bandwagon.
    Tom_W1987
    You can get that flex by simply altering the stiffness of the linkages (of if for some reason you wanttwist in the frame – remove material frame areas of the carbon frame).
    You could even do this by drilling the linkages if you’ve got the balls or know how.
    Btw – I dont like 650b+, they’re vague, roll too much and don’t stand up to rock gardens in sensible weights…procore is the way foward due to the more progressive nature of the tyres equipped with it..which engages the suspension quicker offloading damping duties to the suspension whilst achieving more grip at the same time… nor do I like framea frames that are too laterally stiff.
    If steel was so wonderfull, Ducati would still be using it in their Moto Gp bikes – as would everyone else – they aren’t.
    deviant
    Ducati still use steel trellis in their road bikes, their original MotoGP frames were also steel trellis and apparently a joy to ride….Ducati entered some fallow years when they went over to carbon and couldn’t get it to work in the same way….it’s only in recent years they’ve got their head round it and built a rideable bike….but it’s still a fickle machine compared to the conventional longer beam layout (steel or alu) which allows for what the riders term as feedback and allows them to manage their tyres better over race distance….the major criticism of Ducati’s carbon box section frame in recent years is it’s ‘dead’ feeling and that has come from a multitude of riders.
    Re. the demise in road bikes, weight sells….if you’re peddling a steel frame sports bike weighing 220kg and making 150bhp you’re going to lose out to a rival marketing campaign selling a sports bike with the same power but with an alu frame bringing the bike in at 200kg…..even if your steel frame bike rides better.
    Most bike journos rate the steel frame Honda CBR of the 90s over what came next.
    Quick edit
    ….despite my vociferous defence of steel I really don’t have a dog in this fight, in fact I may be a bit hypocritical as my new HT is aluminium and easily the best I’ve owned….as someone else said, geometry is more important….that said my steel Ragley and On-Ones were brilliant, my steel Dialled was rubbish.
    kayak23
    Here’s another nice couple of pictures of lovely steel frames to balance up all the unnecessary chat… 🙂
    mick_r
    Well last night I had a very pleasant evening in the shed brazing some chainstays to a frame. I don’t think messing with smelly pots of resin, foam and CF would have been as nice. And when the next couple of frames are finished, I’ve got an itch to try doing a steel full sus.
    I guess steel is slightly old tech – but mentioning Reynolds 531 is pretty odd – that is an old alloy (Manganese Moly) that hardly anyone uses (all I can think of are the similar alloy T45 tubes used by Curtis). Air hardening 853, 953 stainless, Spirit, Aermet, Oxplat etc are quite different to 531. And does old=bad anyway?
    Saying that – your modern steel (and aluminium) tubes will still contain some of the “old stuff” in recycled form. I love materials that can be 100% recycled into high grade new products. Every foundry I’ve been to puts a pile of scrap back into the pot, and every extrusion plant had some kind of re-melt facility.
    Can’t say the same for carbon. I shudder every time the car industry blags on about using mass market composites – the scrapheaps of Trabants showed us why non recyclable / low grade recyclable bodyshells were a very bad idea.
The topic ‘Steel bikes going against the curve’ is closed to new replies.
