Home Forums Bike Forum Sram / hope chainring compatibility
Viewing 11 posts - 1 through 11 (of 11 total)
  • Sram / hope chainring compatibility
  • RagTi
    hi
    I ride a codeine with sram X11 crankset, I recently purchased an 1×11 narrow hope 34t chainring and dropped it at the LBS to swap it over. A day later I get a call telling me won’t fit ?, and need to get a sram one ?, never heard of this…..its a small shop but is this the case ? , after shelling out £40 notes is bad enough but I’m looking at another £55 for a sram one.
    Any help appreciated, as ever
    Kev
    robgclarkson
    They’re right, funny that!
    Insomuch as it won’t fit, the hope one will be 104mm bcd, and the X1 crank is 94mm bcd, Google away to find an appropriate chain ring, doesn’t have to be a SRAM as such
    slordy
    Yes it true sram spider only compatable to sram chainring, worth spending a bit more and put a different spider on then you can put any other chainring on in future as opposed to having to use sram only
    wiggles
    Yes they are right not just trying to rip you off…
    You can get a raceface direct mount one for £55 and remove the spider and save weight.
    RagTi
    Thanks gents, much appreciated !!!
    Kev
    brickwizard
    So is it possible to remove the spider on a SRAM XO1 crank to enable direct mounts to fi? If so how does the spider come off?? Ta
    brickwizard
    So if I remove the XO spider can I then fit direct mount chain rings??
    robgclarkson
    Yep
    brickwizard
    Happy days cheers fellas
    brickwizard
    Just remembered I have sram X1 crankset. Would the same apply??
The topic ‘Sram / hope chainring compatibility’ is closed to new replies.
