Home Forums Bike Forum Squelching Fox Float X2
Viewing 15 posts - 1 through 15 (of 15 total)
  • Squelching Fox Float X2
  • simons_nicolai-uk
    I popped the air can of my X2 last week to add back an air volume spacer I’d removed.
    Riding yesterday it’s sounding ‘squelchy’. I pretty sure that previously it was silent. A bit of googling suggests this might be damping circuit seal failure?
    Any advice – heading to Spain with Basque MTB on Friday so not really time to get it warrantied (and it’s only a couple of months old
    RickDraper
    Could be oil squelching between the 2 air chambers but IMHO its more than likely the damper has failed.
    Ming the Merciless
    Mines doing it too, I’ve tried adding air to the piggyback to no avail so off to South Coast Suspension it’ll be going (after I properly break it on Dartmoor next week, bloody timing…..)
    Tom_W1987
    This is why I’d always send my forks and shock off for a service a month before I leave to go on a riding holiday.
    Don’t avalanche add a heavy duty IFP to the X2 series of dampers because of this?
    simons_nicolai-uk
    The shock’s only been on the bike about 2 months…
    Tom_W1987
    Did you buy it from Mojo or TF Tuned?
    Or did it come with the bike – or from an online reseller?
    Again, with the latter two cases – I’d still send both the fork and shock in for a service.
    Onzadog
    You’ve just about got time to get it serviced. Also, it wouldn’t be the first time Chris At mojo would have sent stuff out to Basquemtb at high speed.
    It’s unlikely anything but a proper service is going to cure it and it would be a shame to spoil the back country trip with a knackered shock.
    Tom_W1987
    Yup give Mojo a call and tell them your situation.
    Onzadog
    Plus, even if it came with a bike, mojo do the warranty work.
    The fact that you can’t even do an air can service on an X2 a home is what puts me off an otherwise fantastic shock.
    The tools alone appear to cost over £400
    Tom_W1987
    There’s a cure for regular air can servicing….care to take a guess? 😈
    slickandslide
    Last few we have see have all dumpedl the damper oil into the aircan, including 2 2018 ones that had been on the bikes for 3 days!
    Onzadog
    Do you mean avalanche have been dumbing oil or standard x2?
    Tom, it’s a good idea but manufacturer advises against coil shocks for my frame.
    simons_nicolai-uk
    I popped the aircan open today (at least the bit you can get to) and there was no sign of excess oil there
    Tom_W1987
    manufacture advises against coil shocks for my frame.
    It has a boost valve, so you can make them nice and progressive. Would that work for your frame? Sure – it’s not a twin tube damper, but it is the single most reliable shock there is. Wonder if you can pick them up unused still?
    Also, havn’t PUSH (if you can stomach the cost) tuned the 11-6 for some regressive bikes?
    slickandslide
    The standard X2.
The topic ‘Squelching Fox Float X2’ is closed to new replies.
