Home › Forums › Chat Forum › Should we consider nuclear energy to be clean ?
- This topic has 150 replies, 50 voices, and was last updated 6 months ago by squirrelking.
1enigmasFree Member
Its not. Its lower carbon but not zero. a lot of pollution in the lifetime of the plants.
It’s much, much less carbon than fossil fuel through life, not quite zero admittedly but orders of magnitude in terms of CO2/kWhr compared to any fossil fuel source. Same argument can be used both for carbon-based fuels in extraction/transportation/refinement, or for the pollution made during the production of renewable energy.
We have had several serious radiation spills and still have loads of reactors to dismantle yet.
I challenge the definition of serious there, we’ve had no reactor incidents in either the commercial or naval world that have resulted in the loss of life or the meaningful contamination of land outside of the power plant itself since windscale, which was nearly 70 years ago. For all the arguments against nuclear power the safety one is very dubious in the UK.
the only sustainable solution is use less energy.
We have no choice with the electrification of transport and heating. Nuclear power is the best way of achieving that increase. The UK lacks base-load renewables and nuclear is much better than continuing to consume fossil fuels. I honestly find the argument that we’re offloading the problem of waste to the next generation(s) to be baffling, would you want nuclear waste buried (properly) underground doing nothing, or billions of tons of CO2 (and equivalents) contributing towards climate change – something much, much more tangible to people’s lives.
tjagainFull MemberWe have no choice with the electrification of transport and heating
Of course we have a choice.; The choice is runaway global warming or using a lot less energy. Thats the choice. We have already reached 1.5 degrees of warming, 2C is baked in. 3+ C will happen without radical change to consumption and will result in huge numbers of deaths.
1squirrelkingFree MemberNo it’s not, stop being dramatic.
You’re absolutely right that everything comes at a carbon cost and we need to be consuming less but the choice isn’t amish vs gigadeath.
Your sums always assume that the low carbon option is built or serviced using fossil fuels and never with those same low carbon options.
Not forgetting the vast public subsidy required to make it economically viable,
Commercially viable, there’s a difference. Usually centred around the long-term payback periods, much like hydro.
Up to a point. It’s heavily reliant on imports and exports from other sources (and countries) to balance the grid,
How is that an issue? Diversity of supply is a good thing!
and is vulnerable to high river water temperatures in heat waves.
Any thermal power station would have the same “vulnerability”, high cooling water temps mean the turbine condensers can’t pull as good a vacuum which hurts efficiency. It will still throw out megawatts though and could be mitigated with vacuum boost pumps.
stingmeredFull Member@squirrelking I’m also in the industry. Agree with everything you’ve said so far, except Dounreay. I was heavily involved in Dounreay decom for some years. Re weapons… let’s just say you are 💯 wrong on this one.
squirrelkingFree MemberHuh, fair enough, I thought all that stuff got done at AWE. Or are you talking about breeding fissile material?
molgripsFree Memberthe only sustainable solution is use less energy.
That is not a solution on its own. We need to use much less energy AND that energy needs to be renewably generated.
And we need to address all the other sources of carbon emissions besides energy generation.
argeeFull MemberI couldn’t say. 🫣
Especially if you’ve signed the official secrets act
stingmeredFull MemberAnd you can’t say whether you’ve done that either, as that information is in itself classified.
1politecameraactionFree Member@stingmered: Don’t think that’s true. Are you conflating the notification provisions of the (now dead) Official Secrets Act with the rule around security clearance that you weren’t supposed to go around advertising the fact you’ve been security cleared?
I couldn’t say.
“I said, what colour is the bike shed at Dounreay?”
molgripsFree Memberenergy not electricity Molgrips
I said energy. What are you on about?
DelFull Memberthe only sustainable solution is use less energy
Did you read anything about TWRs?
DaffyFull Member@squirrelking: I couldn’t say. 🫣
Everyone should stop talking about it. I shouldn’t have mentioned it and we definitely shouldn’t add more detail.
DaffyFull MemberThe point was that fast reactors would be a solution to both problems but at a cost, both financial and in terms of risk. Gen IIIs don’t do this, but are still prohibitively expensive.
SMRs also don’t solve the fissile material and waste problem, in fact they make it worse, but they might make the economics more favourable. I’d argue the risk increases. More plants is just more chance for error.
johnnystormFull MemberEspecially if you’ve signed the official secrets act
The signing of the act is a performance to remind you that the law applies to you. Whether you sign or not the law is still the law.
johnnystormFull MemberFor all the arguments against nuclear power the safety one is very dubious in the UK.
Details on the risk here:
https://www.gov.uk/government/publications/radioactivity-in-food-and-the-environment-rife-reports
squirrelkingFree MemberThe point was that fast reactors would be a solution to both problems but at a cost, both financial and in terms of risk. Gen IIIs don’t do this, but are still prohibitively expensive.
What risk do fast reactors pose that Gen III doesn’t?
I’ll be honest and say none. Fast reactors are actually safer as you can’t get criticality above a certain level or it shuts itself down due to physics, they’re passively safe.
Actually you can run them in deproliferation cycles. GE were trying to sell us PRISM to do that years ago but it was a hilariously bad deal where we paid for the reactor, we sold them fissile plutonium, they converted it to non fissile plutonium and we bought it back! Fast reactors also have less high level waste, granted it’s still active in the tens of thousands of years scale but that’s a tenth of conventional reactor types. You wouldn’t run them in isolation either so you would have power stations like we have now with the same training and expertise. It’s not something you just dump on the back of a lorry and leave in an industrial estate with a remote operator.
politecameraactionFree MemberThe signing of the act is a performance to remind you that the law applies to you. Whether you sign or not the law is still the law.
Not…exactly. per s1(6), if you were not a member of the security or intelligence services, you had to be notified in writing that you are subject of the provisions of s1(1) of the old Official Secrets Act. So it’s not so much the signing that’s important, you’re right, as the receiving…but the signing is evidence that you received the notice.
https://www.legislation.gov.uk/ukpga/1989/6/section/1
I painted the bike shed at Dounreay (using glow in the dark paint).
dyna-tiFull MemberEspecially if you’ve signed the official secrets act
In triplicate, which makes it especially binding.
Or is it four times, i cant remember 😕 you do what you’re told, or get shown the door.
thols2Full MemberJust out of curiosity, what happens if you refuse to sign? Do you get dragged off to a dungeon, put under surveillance…?
FuzzyWuzzyFull MemberThere’s not really any choice but nuclear for the foreseeable future, SMRs (Small Modular Reactors) are a bit more concerning in terms of potential environmental impact but they’re on the way, like it or not. The race towards AI will drive some of it, they’re building GW datacenters now (that house super-dense compute racks, mostly for AI workloads) and those really need local power generation
ransosFree MemberHow is that an issue? Diversity of supply is a good thing!
Yeah, but running nuclear above baseload, as the French do, makes the grid reliant on it. We can’t all “do a France” as there would be no-one to trade with! I agree that a diverse mix across Europe is helpful.
Not to the point of shutting down I think? Of course, non thermal sources are unaffected, the very sources which compete with nuclear for funding.
DaffyFull MemberThe thermal management system for fast reactors (my knowledge is from Na) was far more complex, far harder on components and thus needed more safety systems and more maintenance which made them more than a little more risky, They also, to my knowledge, are not as reactive (to demand) as more traditional PWRs, and in the event of a serious problem with the reactor, an assessment has to be made as to HOW critical a fault was as a full shutdown and cooldown essentially killed the LM jacket surrounding the core and the thought was that this would mean a full core replacement. Obviously this was all theory.
The final problem with LMFBRs is that you do end up with significant amounts of radioactive waste from non fissile material in the form of the reactor jacket used for neutron capture.
tjagainFull MemberThere’s not really any choice but nuclear for the foreseeable future,
Apart from the facts that they are an expensive diversion and can never be a significant part of the fight on global warming. 30 years to build a plant, only provide a few % of the worlds energy needs, no fuel for the massive expansion needed to have any significant effect on global warming, no solution to waste.
But apart from that…..
molgripsFree Memberthe massive expansion needed to have any significant effect on global warming
How much expansion is that? We are talking about base load in an energy efficient world, aren’t we?
I don’t think anyone’s suggesting carrying on wasting energy with 100% of our generating needs met by nuclear, are they?
argeeFull MemberApart from the facts that they are an expensive diversion and can never be a significant part of the fight on global warming. 30 years to build a plant, only provide a few % of the worlds energy needs, no fuel for the massive expansion needed to have any significant effect on global warming, no solution to waste.
So what is the solution to the increased requirements for electricity consumption now and in the future for the UK?
As others have stated, there are solutions for waste, it’s on-going management, it’s not as if it’s being fly tipped or lost at present!
tjagainFull MemberHow much expansion to have a significant effect on global warming? At the moment nuclear is just a few % of the global energy usage. To have any significant effect it would need to be many times this. No new reactors can be built in time anyway.
tjagainFull MemberSo what is the solution to the increased requirements for electricity consumption now and in the future for the UK?
Reduce energy usage – thats all energy not just electricity. ALL energy usage comes at a carbon cost.
New nuclear takes 30 years to be built. Too late.
molgripsFree MemberTo have any significant effect it would need to be many times this
Show your working here please as I think you are mis-understanding something.
Right now, on a still morning before the sun is up much we are on 35% fossil fuels, 18% renewable and 17% nuclear (and also buying a fair bit). So even replacing all our fossil fuel with nuclear right now we would need triple the nuclear power stations we are now using to get to zero generating emissions.
However, that won’t be needed in reality since we are increasing our wind capacity significantly, and I’m pretty sure we will end up with energy storage which at a time like this (8.45am) we will be able to offset against solar later in the day.
nickcFull MemberNew nuclear takes 30 years to be built
This web-page suggests 6-8 years to build. Obviously their may be a long planning tail, but that’s not necessarily true of every project.
squirrelkingFree MemberYeah, but running nuclear above baseload, as the French do, makes the grid reliant on it. We can’t all “do a France” as there would be no-one to trade with! I agree that a diverse mix across Europe is helpful.
Ah right, sorry I see what you mean now. Yeah the French system isn’t great but works because of interconnects. You could make the same argument for any sub-grid, it’s just a different scale. Having large prime movers is good for grid stability but they should ideally be spread out.
I don’t know tbh, it depends on what’s driving the need to shut down.
Citation please.
Olkiluoto 3 started construction in 2005 and was commissioned last year. 18 years.
Flamanville 3 started construction in 2007 and is due for commissioning this year. 17 years.
Taishan 1 started construction in 2009 and was commissioned in 2018, Unit 2 was a year later for both. 9 years.
Hinkley C started construction in 2016 and is due for commissioning in 2030. 14 years.
That’s just EPR’s (which have now been refined to EPR2). As I’ve pointed out in the past ABWR’s are much quicker. In our case a lot of the delays are from a loss of skills. We hadn’t built nuclear for over 20 years, you can’t just expect people to get up to speed straight away after all that time. Factor in that we had a model that needed redesigned to satisfy the ONR and I’d say we’re doing well, obviously could be better but that comes with repetition and learning where you can make efficiency savings during construction (like building things on the ground and craning them in rather than in the air once the larger part has been fitted).
tjagainFull MemberHInckley C was supposed to be online by now and the project was started well before that
Actual time from deciding to build to starting to generate is 25 – 30 years for all recent reactors. You are using a false starting point. Its from decide to build to generate electricity – which is 25+ years. Hinckly is already 15 years late and now pushed back to 2031
Molgrips – once again TOTAL energy usage worldwide not just electricity generation in the UK
Nuclear is around 4% of the worlds total energy usage. To have a significant effect on climate change it needs to be many times this
We have no storage solution yet or on the horizon
nickcFull Memberactual time from deciding to build to starting to generate is 25 – 30 years for all recent reactors.
Long planning time is true for all large/massive construction projects though, and isn’t just peculiar to or a feature of nuclear. It’s not necessarily that each project has to take that long, it’s just that they have in UK in France becasue the need for additional generation hasn’t been so urgent that there’s time pressure to get it built. In Korea, Japan and China for instance the project times are much faster. Past project length times to build aren’t necessarily a good indicator of how long it would take to build smaller modular reactors in the future if there was political will/public pressure for cleaner energy.
I don’t think it a useful counter to why they shouldn’t be built.
molgripsFree Memberthe increased requirements for electricity consumption
What increased requirements?
molgripsFree MemberMolgrips – once again TOTAL energy usage worldwide not just electricity generation in the UK
So.. because nuclear can’t solve the entire world’s energy needs, that means we should not install any? You do understand that we need a mix of energy sources, right? We don’t need to go with just one.
When was the last time you read up on this? Serious question.
argeeFull MemberWhat increased requirements?
The predicted increase due to the reduction in gas usage and increase in electric cars/trains/etc.
tjagainFull MemberSpending all that time and money on nuclear means that is not spent on more workable solutions. Nuclear cannot be the saviour technology. Its a distraction from the real issues
Local battery storage is useful but once again a tiny % of what is needed. We need global solutions quickly scalable
nickcFull MemberNuclear cannot be the saviour technology.
I don’t think anyone thinks that’s true, do they? there’s only 100 or so years worth of usuable material anyway , so it’s never going to be the “solution to everything” but that could be the 100 years space that someone needs to get on with transitioning to use less, or build some other form of sustainable power generation
I disagree. The future energy crisis isn’t going to be solved by just doing this thing , or only doing that other thing, it’ll be a mix of solutions. Just like we can build roads and rail at the same time…Nuclear might not be that answer to everything, but it’ll the right solution in some instances. Dismissing it out of hand is short-sighted
