Shimano shoe fit ch...
[Closed] Shimano shoe fit change ?*%! (Am9 + ME7j
My most worn shoes in the last year have been my AM9(01) and MW7 boots. Both are 46 and fit well.
Ordered new shoes from bike discount - ME7(02) and AM9(02), both in 46. I’d had a pair of the me701s previously which were warrantied when the mesh toe failed.
Neither of the new shoes fit. Much tighter across the forefoot and the lace cover/straps barely domip (I’ve got a high instep). They’re about the right length so going up a size almost certainly won’t work)
Are the latest version of the AM9 (903) the same or do I just have to accept Shimano no longer fit me (in which case suggestions please for similar alternatives).
Posted : 21/05/2022 11:11 am
I've had the opposite problem. I'm a size 42 in most footwear. My old Shimanos are size 42. The new models I bought in size 42 are a bit on the large side - probably half a size.
Posted : 21/05/2022 11:16 am
The ME702 came up small for me, I'm usually 45 but had to go for a 46. I also have a high instep but they fit quite well. The one change I had to make was use different insoles, I think the stock ones are quite thick and didn't make for a comfortable fit for me. Changing insoles moved the fit from a 6/10 to a 9/10
Posted : 21/05/2022 11:43 am
Don't they do two width sizes now? Changed a few years ago.
Posted : 21/05/2022 11:46 am
@oldnpastit
That would explain why the ME7 also have “volume + last” on the side of the box along with all the other stuff but unless the alt is volume ++ they’re still way smaller than the me7 v1s I briefly owned.
Edit. Ok, here’s the lowdown:
https://bike.shimano.com/en-US/technologies/apparel-accessories/footwear/more-lasts.html
https://bike.shimano.com/en-EU/technologies/apparel-accessories/footwear/last-technology.html
Looks like I probably need the volume performance last. Not clear of these are options on the same shoe or on different models. (Yes it is. Table at bottom, scroll right)
Posted : 21/05/2022 12:50 pm
But that table says that the MW701 (which I have and which is a great spacious fit even with woolyboolies) is the same fit as the ME702 which is too tight with thin socks.
Shit. And this table
Has the volume + last for the me701 which you’d expect to be the same as the 702 listed here
which it clearly isn’t.
I hate buying shoes.
Posted : 21/05/2022 1:15 pm
