trouble sorting thgears on teh wifes cube ams
put a cassette and chain on that hav had 100 miles dry use on the cross bike on road as the stuff on there was not shifting properly around the middle gears and no amounts of patience with the barrel adjuster would work so assumed just to worn.
stuff on as i said was new 100 dry road miles ago so thought should be no problmes.
if get it shifting correctly up from 11 cog to the next 2 or 3 cogs, it then insisits on jumping up 2 higher up the cassette from 4 easiest ot 2nd easist cogs. If i get it shifting correctly at the top end of the cassette it won’t shift up enough to get off the 11 t cog and the next 2.
Any possible solutions or ofers of how to sort it greatly apreciated as it is now annoying me. Can it be the rear mech on its way out, its a few ears old but not seen that much use.
ta
