Hi, I have a santa cruz blur classic that requires a bit of work done to it- Bearings & pivots need replaced, which will not be a cheap rebuild. Also as its a very old blur classic, the clearance at the back isnt great- it fits a 2.35 maxxis, but usually is full of mud & whatever else at the end of the ride. It has a decent spec on it, Blackbox rebas, DT wheeset XT / XTR drivetrain, xt brakes etc etc. So I was looking at replacement frames, and came across the camber, which would suit my needs as it has 135mm / QR droputs, 120mm of travel etc etc.
Obviously its dificult to get the frame on its own, but I have found one for sale secondhand, but it doesnt have a shock. The dimensions of the shock on the blur seem to be the same as what the camber needs, is it just a matter of swapping them across, or would the shock tune need changed to suit the differant linkage behavour?
So, good idea or no? Am i just better off getting the blur sorted? Obviously new shiney shiney factor comes into play! Ta for any advice!
